I bought a seal USB turntable without software where can I get software for it
  • Phil
    Phil Apr 10, 2011
    What is the model number??
    http://www.seal-usa.net/Eng/download.htm has all of the current drivers for SEAL products
I need audio software for electro brand usb turntable 2690.
Turntables rarely play cassettes.
Try the manufacturer's website.
Mar 30, 2013 | Audio Players & Recorders
Does anyone know a download so i can get my discover dj computer system to work because i dont got a diskf or it i bought the machine off my buddy
It apparently works with USB and requires no further downloads to get it to work.
There IS however a software CD that should've came with it; hopefully your friend gave you that CD too. That CD (according to their video on ION's home site found here, inserting that software disc into the computer is one of the steps to getting the DJ turntable system to work.
Oct 20, 2012 | ION Audio Discover Dj Turntable
I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
hi,
yes you need an amplifier with or without phono input.
your turntable has three types of output
1.phono output (can connect to the phono input of an amplifier which has a phono input)
2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
there is a selection switch for phono or line level output on the back side
3. and usb( to computer)
Jan 06, 2011 | Stanton T55 USB Turntable
I bought an Audio Technica USB AT LP 120 Turntable last June. It worked fine as a turntable, but I was never able to get good recordings of vinyl without distortion. But now I have another problem: when...
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Dec 05, 2010 | Audio Technica USB Turntable
When I go to Record there is no sound and the control panels do not move
Make sure the correct source is selected for sound in audio properties (Right click the volume icon near the clock). The device must be the turntable driver.
Make sure you have installed the Numark software BEFORE you plugged in the turntable to your computer for the first time.
If you have done the faux pas above, all the installs in the world will not fix it. You MUST remove the USB driver. Use Device Manager. In XP, this is found by right clicking my computer and selecting properties. In properties select the hardware tab and choose 'Device Manager'.
Stop here. If you have no idea what I wrote, review 'Device Manager' on the Windows Website or ask a KNOWLEDGABLE friend for help. See http://support.microsoft.com/kb/310123.
Now, select the USB device, while it is plugged in to the USB port, and right click. Select 'Uninstall'. Remove your USB device when device manager is done.
Close Device manager and all the other windows. Start your USB install from scratch, without the USB plugged in until the install asks or completes.
I have ALWAYS had successful installs with this method.
Mar 21, 2010 | Numark ttUSB Turntable
Prolectrix usb turntable
I found it works if you select the one that starts with USB
Feb 01, 2009 | Audio Players & Recorders
Need driver for windows to have the Crosley CR249 turntable work correctly.
Insert the enclosed software cd into your computer.
Follow the instructions on the computer screen to install the software. If the software does not load automatically, browse the cd and open the Read Me folder for further instructions.
Connect the small end of the USB to the USB jack on the back of the unit.
Connect the other end to a USB port on your computer.
On your computer open the Record Recording software.
For instructions on operating the Record Recording software, browse the software cd and open the Read Me folder.
I got that from the manual. You don't need a separate USB driver for it, mate, but you DEFINITELY need the cd...
Hoping you have the cd,
Chris (ziraffa)
Dec 28, 2008 | Crosley CR249TA Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Does Cakewalk Pyro 5 work easily with a USB turntable
Yes, Cakewalk Pyro 5 works well with a USB turntable. It has specific support for USB turntables. One example of a turntable that works well with it is the Stanton T.90 USB Turntable.
Nov 14, 2008 | Cakewalk pyro 5 Full Version for PC
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
