Question about Miele W418 Washer
I have a Miele W918 front loader washing machine and it won't finish the wash cycle. The water tap icon keeps flashing red. ie it has sometning to do with the water inlet (I think)
  • 21 Answers
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
Posted on Feb 14, 2009
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
  • 70 Answers
SOURCE: What do you do if the Miele washing machine's
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work.
Posted on Mar 29, 2010
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
  • 713 Answers
SOURCE: My F & P top loader machine drips from the
Hi just read your posting.The 2 faults with this problem is faulty tap washers and faulty water valves.To stop the water coming into the machine then you must either replace the washer in the tap or replace the water valve.I can help you replace the water valve if you decide to replace it.Please reply on how you would like to proceed.Looking forward to your reply.
Posted on Oct 09, 2010
Miele w918 washes much longer now than before. About an hour longer, even with shortened program. Any ideas?
Maybe the water is not getting into the machine as quickly as it used to. You may have a filter on the hose connection. Does the water appear to be filling as fast as it did before?
May 19, 2015 | Miele Washing Machines
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
I'm looking for a service manual for Miele WS 5425 washing machine, any ideas where i can obtain one?
i have a Miele ws 5425. it wil not open even though though the cycle has finished. It still full of water. The red fault light flashes on the drain symbol.
Jun 17, 2010 | Miele Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Miele W418 Washer Logo
405 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
