Question about Breville Die Cast 800ESXL Espresso Machine
My breville 800es turns on,all lights ok,does not heat water,does not pump & does not steam.Thermostats & thermal fuse ok.Power is reaching circuit board.Is it a circuit board problem?maybe a diode? but which one?
SOURCE: No water is being pumped at all
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Posted on Dec 26, 2007
  • 7 Answers
SOURCE: No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Posted on Mar 18, 2009
EsWorld
  • 1618 Answers
SOURCE: Water flows fine until we put in the Filter Holder
The grind on the coffee is too fine, try packing it lighter or setting the grind coarser.
Posted on Jun 30, 2009
beltronic205
  • 1461 Answers
SOURCE: Online store for Breville spare parts?
Try espares.co.uk or Currys partsmater
Posted on Apr 05, 2010
SOURCE: How to replace the swivel
Click on the link below to view the Breville 800ES expresso machine owners manual. Inside this manual it will show you how to replace the swivel steam wand:
http://www.breville.com.au/ssl/cms/files_cms/800ES%20Book.pdf
Posted on Dec 15, 2010
Can I run the hot water heater with a generator
Yes.
Ordinary electric water heater can run on any voltage from any direction (excluding volt/amp ratings below what can heat element coil).
Voltages include single-phase, split phase, and 3-phase residential/commercial voltages with either 50 or 60 Hz.
http://waterheatertimer.org/How-to-wire-water-heater-for-120-Volt.html
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#3-phase
Install line fuse.
30 amp fuse would be required to prevent wires from overheating, and eliminate fire hazard.
This information does NOT apply to energy-smart electric water heater with box on top of heater, or newer energy smart with electronics, or to hybrid water heaters, or heat pump water heaters with delicate electronic circuitry.
Why it works like this:
Ordinary electric water heater thermostats are mechanical bi-metal switches and respond to tank temperature, and are not operated by electricity.
Ordinary generic elecrtic water heater thermostats switch electricity on-off using mechanical bi-metal switch.
Heat elements are simple coil of thermal wire that gets hot when voltage is applied.
The element will get hot when power is applied.
Oct 29, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The difference between thermal fuse and thermostat
Thermal fuse is a heat-sensitive safety feature that shuts down system when overheating is detected.
In electrical wiring, the thermal fuse reacts to high temperature caused by too many amps on the electric circuit. When temperature exceeds the fuse amp rating, then the fuse trips and cuts power to electric circuit.
Example of thermal fuse is a household circuit breaker.
Gas water heaters have a different type of thermal fuse located in the combustion chamber or on the combustion chamber door, and also inside a copper probe inside water tank. Water heater thermal fuses will trip when water temperature exceeds fuse rating, or when heat inside the combustion chamber exceeds temperature rating of fuse. This action will cut off gas supply to water heater.
So a thermal fuse is a safety feature.
Thermostat is not a safety feature.
Thermostat is a measuring tool.
Thermostats measure temperature.
Example of thermostat is outdoor thermometer, or cooking thermometer, or Heat-AC control located on wall inside house.
Thermostats can give a simple temperature reading, or they can cause a separate control to turn on-off depending on application.
For example thermostat on Heat-AC will read room temperature, and when temperature exceeds setting, this triggers a switch that turns Heat-AC on-off.
Many appliances have both thermal safety fuse and thermostat.
Take for example a gas water heater. A copper tube extends into the water tank. Inside the copper tube are 2 things: A thermostat probe to measure water temperature, and a thermal fuse called an ECO for energy cut off. The ECO is a thermal fuse, and is a safety feature.
http://waterheatertimer.org/images/Gas-valve-ECO2-358.jpg
The thermostat reads temperature of water, and turns water heater on-off to keep water hot. A person can adjust water temperature by adjusting the thermostat dial on front of water heater.
However if the thermostat fails, or some other problem occurs, and water inside the tank gets hotter than 180 degrees, then the ECO or thermal fuse will trip. When the thermal fuse trips, this turns off gas to the water heater so water cannot get any hotter. The safety device prevents water heater explosion. The water heater must be repaired since this particular thermal fuse cannot be re-used afterwards, and must be replaced.
Oct 11, 2012 | Dryers
Difference between thermostat and thermal fuse
Hello Mary
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
Dryer over heated and power switch wont work now to
Most likely, the thermostats have failed. The machine heated up too much and the thermal fuse turned it off permanently to prevent a fire.
Unplug the machine! Check the thermal fuse for continuity with a multimeter. If it does not have continuity, replace the thermal fuse and the thermostats. If you do not replace the thermostats, the thermal fuse will probably burn out again.
Apr 29, 2010 | Whirlpool LER3622 Dryer
Coffee maker doesn't heat when turned on
We are having the same problem. Any answers?
Feb 17, 2010 | Krups FME4 Coffee Maker
FrancisFrancisX3 - no power
There are 3 thermostats in the unit- one for the water temperature, one for the steam temperature, and one fuse which blows if the unit overheats. The overtemp fuse is a 'fuseable link' that burns out if the boiler gets too hot (maybe 150C). If that fuse is blown, then you probably have other problems, since the unit won't get that hot unless the steam thermostat fails.
Even if the thermostats have failed, you should get the power light when the unit is plugged in, and the pump should work, but the boiler won't heat up. If you get no power at all, then you have a wiring fault somewhere.
Oct 18, 2008 | FrancisFrancis! X3 Espresso Machine
Makes espresso, coffee, water, but will not steam
The pump has gone bad - through use. This is a common problem, and has to do with the "seals" that are in the pump. Since the pump generates high pressure and heat, over time, the seals will fail, and will be unable to generate enough pressure and heat to create steam. The only remedy is to have the pump replaced through the Breville Out of Warranty repair centers.
http://www.brevilleusa.com/support/service-centers.pdf
Dec 11, 2007 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
43 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
