Question about Hotpoint Ultima WF860 Front Load Washer
My washing machine says F 05 - Hotpoint Ultima WF860 Front Load Washer
    Brigadier General:
  • 6,277 Answers
Hotpoint (Indesit) 'F05' means 'pump blockage'.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 11, 2011
Washing Machine Aquarious Ultima the screen shows F 05 ? it does not finish washing and the door can not be opened
Hello there:
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Dec 26, 2010 | Washing Machines
Washing machine code f-05
Hello there
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Dec 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Jul 01, 2008 | Washing Machines
F-05 WD640
f-05 pressure sw stuck on full this is a faulty switch
Jun 22, 2008 | Hotpoint Ultima WF860 Front Load Washer
Fault code or engineers reset for beko washing machine wma 756s serial no 05-100 905-06
please can you send me fault code for beko wma 665 w serial no 05-103296-10 thankyou
Dec 21, 2007 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
