Question about Garden
Pullcord snaps out off your hand and the mower wont start
  • 2,510 Answers
From your description, I would say you should remove the spark plug and pull the engine over several times. Replace the plug and try starting it again. If it still does not start, come back to me with the new symptoms and lets take it from there.
Posted on Apr 10, 2011
Pullcord slipped back to motor how do i release it
you will have to take starter cap off to free the cord
Oct 01, 2014 | Garden
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
Lawnmower repair manuals
Goggle replace pull cord on mower. They are all the same to repair.
Jan 04, 2014 | Garden
How do i start a rover 03026S
is there a prima at the front of the air filter if there is push it in 5 times then put throttle flat out ond pullcord,if dosnt have prima put throttle to choke pull cord and when starts pull throttle off choke,if dosnt start after five pulls take off choke and try starting again
Feb 04, 2013 | Garden
Pullcord wont pull out to srart engin
ok. 1. you are not pulling hard enough,or the turning of the motor is jammed or seized. look under mower deck for an object jammed w/the blade and deck.
Apr 24, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Shrieking Lawnmower!! I hit small tree branch w/ walking non-drive 3.75 hp Briggs and Scrap-Iron "Sprint" off-brand gas mower. Started shrieking like banshee. Resulted in tangled pull-cord. So I removed...
sounds like you have dirt in the recoil clutch, (under the screen) or you bent something there. try removing the clutch and make sure shaft is very clean and lightly coated with oil. This would be for a briggs and stratton engine.
Jul 25, 2009 | Garden
Rewinding pullcord on briggs and stratton mower engine
The spring in the cord rewinder is probably broken or loose. Need to tak it off and investigate.
May 04, 2009 | Husqvarna Garden
Cannot start. The pullcord will not move
If it wont pull you probably have ceased the piston in some way. You can get access to the piston by removing the exhaust baffle. Or disassembling the entire saw.
Try putting a screw driver in where the exhaust and trying to move the piston just a little bit, back and forth. Once thats done, use a heavier gas / oil mixture.
Apr 28, 2009 | LG WM-1832C Front Load Washer
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
