Question about Lexmark E234 Laser Printer
Paper stops I have a Lexmark E234 that feeds the paper thru the printer and then the paper stops about 3 inches before it would come out of the printer. I have opened the back cover to ensure there is nothing jammed there to stop it and even with the back cover open the paper stops. Any clue?
Check that the rear paper sensor feeler arm is not broken. It is the little black plastic tab that sticks up in the middle of the paper path when your looking at the back of the printer with the cover open. If you can't see it, it's probably broken.
Posted on Aug 09, 2008
  • 876 Answers
When you open the back cover for a paper jam, is there a long roller that you can see? Take all paper out of the printer and turn it off. Very carefully use your finger to roll the roller upward until it clicks. This resets my printer, which is a different model, but it may help you as well.
Posted on Aug 06, 2008
SOURCE:
I used to connect to my Lexmark E234 via network hub, now I need to connect it directly to my computer (OS 10.5.8) via USB cable, but my computer can't find the printer.
Here's a link to the Lexmark website for the Lexmark E234 driver for Macintosh 10.5.8 available for download. http://bit.ly/cqD2zX. Download and install the software. Hope this helps.
May 17, 2010 | Lexmark E234 Laser Printer
On my Lexmark E234 the fourth light down, yellow light is on.
Hi, That light is indicating that there is a paper jam in the printer. Here is a link on how to remove the paper jam and some other instructions on how to prevent it.
http://bit.ly/9Ymse7
Dec 10, 2009 | Lexmark E234 Laser Printer
Hi my name is Lecette. I am having some trouble printing on my lexmark x5470 printer. When I print the paper slides in 3 inches and starts to crumble up and jams. Is there any way you can assist me with...
if the paper is crumpling up then something is stopping the paper from moving check the paper path for obstructions. if your first set of feed roller are moving and the second set is not then this will happen also
Dec 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x83 paper feed problem
If your not qualified to do this I would not sugges you do it, tho here is a solution for you. See if its snapped in place instead of being bolted down. you can also access underneath the unit hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark E234 Paper jam light wont go off
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 21, 2009 | Lexmark E234 Laser Printer
Lexmark X85 Printer
i tried cleaning the rollers off with lens-cloth & paint thinner & got TONS of ink off the rollers, still same problem thoough, but very slight improvement.
Jul 23, 2008 | Lexmark X85 All-In-One InkJet Printer
Paper feed issue
The paper feed tires under the printer are glazed up this happens with use you can use a rubber restorer such as fedron to recondition the tires or you can contact lexmark via their web site to see if you can buy parts thru them and just order the paper feed tires.
Dec 06, 2007 | Lexmark E234 Laser Printer
Paper jams
Fan your paper.
Fan:
Meaning take the paper in your hand and wave it around or page thru the papers, This puts air between the paper to prevent jams.
Make sure you do not over due the paper in the tray. Try lighter paper weight.
Nov 13, 2007 | Lexmark E234 Laser Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark E234 Laser Printer Logo
257 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
