In Xerox 5016 frequently "U2"
5 Suggested Answers
SOURCE: I have Xerox 5016 model
Enter into the diagnostic mode.Press 50 then green button,press 20 then green button,press 00 then green button.Switch off the machine & Switch On.
Posted on Feb 14, 2011
  • 239 Answers
SOURCE: i have a xerox 5016 copier ,
On this model sometimes the plugs on the connectors go bad.
They arc and will not connect good. Sometimes the ends have to be clipped and new pins male and female have to be crimped back on, replacing them on the machine part wiring connectors and fuser rod ends. this fuser kit is a part that is availiable at xerox.
A bad thermistor can cause this type of problem. If the machine overheats, the fuser triac pack can cause over heat problems as well.
On overheats the fuser fuse needs to be replaced. Do not replace with nothing else but a Xerox fuse, this is a safety device. Very important.
Otherwise place a service call to have this area repaired by xerox.
Posted on Oct 26, 2009
MUKHTAR
  • 2017 Answers
SOURCE: xerox 5016 copier error j6
ADF to machine communications problem.kindly call to technician and fix it.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Dec 27, 2010
  • 358 Answers
SOURCE: please help because no driver
My I know the brand?
Posted on Jan 08, 2011
Xerox 5016 error code u70
Error U7, U7-1 (Photoreceptor Belt Drive)
Appears when the Copy Cartridge has Not Been Replaced.
Apr 27, 2011 | Xerox Office Equipment & Supplies
I have Xerox 5016 model Photocopier , I am getting Error U4 ,some technican from Xerox advised that it can be solved by pressing some button ..? If anyone can support would be a great help.
Jan 15, 2011 | Office Equipment & Supplies
Xerox 5016 copier error j6
error no.j6 asking how to swallow prablam
Dec 27, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
Enter diagnostic mode
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
866 people viewed this question
jasbo
jasbo
