Question about HP LaserJet 3055 All-In-One Printer
I was taking print of one document,then suddenly the print got interrupted and this line MEMORY LOW came on the printer.how to get rid of this problem
SOURCE: occasionally bottom line of document only partially prints
Goto Office button-> Print-> properties-> Change paper size to A4
Posted on Nov 24, 2008
SOURCE: My printer has suddenly started printing terrible quality photos
I discovered I had switched photo paper in the process. The new paper obviously isn't compatible with this printer. I went and purchased more of my regular paper and the pictures began printing well again.
Posted on Dec 18, 2008
  • 11800 Answers
SOURCE: Norton keeps taking away my
Norton is corrupted and you must get rid of it immediately before it messes even more. To do that you must use the official removal tool.  After that you should install another antivirus.
For start i must tell you that from now on you should ALWAYS use the Save option , not the Run one, when downloading something from the internet. When you use the Save option a new window will open allowing you to select where the file (or whatever) should be downloaded on your pc; in here ALWAYS use a different location than the desktop, My Documents, Programs or Windows folders - if necessary create a new folder just for that.
Download the removal tool from here
http://www.symantec.com/norton/support/kb/web_view.jsp?wv_type=public_web&docurl=20080710133834EN&ln=en_US
Then download a new antivirus from here
http://www.avast.com/free-antivirus-download
after both downloads are over close all windows except the one with the folder with the downloaded files. Launch the removal tool, wait for it to finish, reboot yourself one more time and launch the installer for the new antivirus. When it's over perform a full scan to be sure your system is clean.
That should fix it.
Posted on Sep 12, 2010
SOURCE: i am trying to print
You need to do setting in Driver Properties printing preferences in advanced tab, select computer memory if printer runs out of memory, if it configured on the network then set properties on computer where driver is installed.
Posted on Feb 08, 2011
  • 713 Answers
SOURCE: Hp8500 will not print a large document and the
right click and delet document and run dacument under fool page in settings.
Posted on Feb 17, 2011
Memory low
When getting the error message Low Memory, this means one of two things. Either the print job that you are sending to the printer is to big, or the fuser in the printer is to hot, and needs to cool down. I would not recommend printing in raster mode, as this can cause further issues within the software. A couple of steps that you could try are:
1. If there are previous print jobs in the queue wait until they are completed
2. Power down the printer for a minimum of 30 seconds
3. If you are printing a large amount of pages, break it down into smaller jobs
4. If printing documents, change the setting to either fast draft, or draft mode
Feb 23, 2014 | HP LaserJet Pro 200 color
Message saying "received in memory", what does it mean and how do I get rid of it?
It means there are pending documents in the memory of the printer awaiting to be printed. This documents could be a received fax documents or a documents failed to send.
Just press the menu button to enter fax setting: under it the appears "receive mode set"...... use the right arrow button to go to "memory referrence" then click OK button.
Use again the arrow buttons to delete documents in memory.
Oct 15, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
One line at top of page it's not what I was wanting to print. Reads like 199v-?=l?n.)?= and so on any help
Stuff like this happens sometimes when you have a bad connection or if the print job is interrupted in the middle by the user cancelling it or a problem on the pc. I would check the cable to make sure that it is securely plugged in and retry it. You didn't say if this problem was recurring or not. If not, just try printing again. Let us know if this happens consistently. Good luck!
Mar 13, 2010 | HP DeskJet 932c InkJet Printer
I cannot interrupt a printing job and then have it stay interrupted,it just resumes printing after turning off for 20 seconds
You need to clear the print queue. To do that, click on start. Then click on control panel. Once the control panel opens, search for printers and faxes. Double click on it. You will see the name of your printer. Double click on it. In the bod that opens, you will see your document. Right click on the document that you want to stop printing. you will get an option to delete. click on it. It may take a few seconds to get it deleted. Once this is done. It will not print. No need to switch the printer off and turn it back on.
Jan 27, 2010 | Brother MFC 240C All-In-One InkJet Printer
Have a E Machine T3504 desktop. When trying to print from an embroidery software it takes forever for it to print. Sometimes have to restart computer. Any ideas?
You might want to check the memory on your printer, since it your printer has a low memory then it could take forever to print. I would check the setting for the printer and see if the box labeled start printing after last page is spooled, becuase then the printer will wait for the entire document, you want to change that to start printing immediately and make sure spool print documents is cheecked.
Jan 02, 2010 | E-Machines T3504 PC Desktop
I cannot get documents to print. There are 79
open the printer and faxes the double click on the printer driver and cancel the all pending document ....... and check the printer status ......... if is it in ready means only you can take print ......
for any clarification please post your comment ....
Nov 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
WordPerfect Printing Problems with HP Photosmart C5550
It's not the program, but the actual printer.
You see, when you print with an inkjet, the information is fed line-by-line through the CPU for processing. The larger the document in size, the longer it takes.
Switch to a color laser printer. They're about 150 dollars. It has an onboard memory and a CPU for processing. Speed wise is about 500% faster. Since it has it's own onboard computer basically, it doesn't need to interrupt the CPU to compute the information and send it to the printer. Laser printers are also known as page printers because they can store pages of information in their own memory.
Aug 09, 2009 | Office Equipment & Supplies
I cant receive fax. it has some in the memory.
if there are a message like empty cartriage or low cartridge that means
the printer want new cartridge for print fax, when it print another document and also print reports without trouble.
Jun 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Problem with fax Memory
This could be very simple. Check to be EXTRA sure that your USB line is NOT plugged into the fax line. (There's a little phone icon). That's what happened to me....boy am i dumb!
Oct 02, 2007 | Canon PIXMA MP530 All-In-One InkJet...
HP LaserJet 3055 All-In-One Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
