Question about Nespresso C190 Espresso Machine
I have a Nespresso C220 and the water doesn't seem to be getting hot and therefore is not flowing through the machine.
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
ginko
  • 19396 Answers
SOURCE: krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Posted on Feb 17, 2009
EsWorld
  • 1618 Answers
SOURCE: Water is leaking into the drip tray.
Clean the chamber below the white plastic valve, there is also a small discharge that leads from there into the drain tray clean that hole also.
Second the thermostat that controls the steam may be damaged or the cpu board, the contact the controls the steam may be damaged, i have seen both of those happen on some units.
Posted on Oct 10, 2009
  • 21 Answers
SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Posted on May 08, 2010
SOURCE: Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Posted on Jun 09, 2010
The lever to puncture the Nespresso pods will not fully latch when pulled down. The only way to have the Nespresso machine brew a cup is to hold down the lever until it is completed.
do not fors it you may have problems wi the piston try runing some worm water with out any capsule until it is flowing properly you may have some blocking in th esystem
Aug 15, 2017 | Nespresso Coffee Makers & Espresso...
Nespresso machine won't puncture
cheak for blocked and run some clean hot water ferst .see water flow be for useing capsule if its blocked or partly blocked the water will go in the waist bin.
Aug 11, 2017 | Nespresso Coffee Makers & Espresso...
When i put in the nespresso cup in the Citiz and close it nothing happens. Ussually it should make holes in the cup so the coffee can come out. But there are no holes when i open it again. So i can not...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Jun 08, 2011 | Krups Coffee Makers & Espresso Machines
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
With our nespresso machine, when you place the capsule inside & press the button the water runs through the inside of the machine where the plexiglass basket for the empty capsules are
Feb 04, 2011 | Nespresso Citizmilk D120
The capsule lock system does not make holes in the capsule
Oct 09, 2009 | Nespresso Le Cube
(from
Nespresso Club)
Sep 18, 2009 | Nespresso C100B Essenza Single-Serve...
Warm wash is almost cold (no different from cool wash). hot water works fine.
What could be happening is the cold side of the inlet valve could be opening with the hot side and therefore it is warm instead of hot
Sep 07, 2009 | Washing Machines
I lost power and now I get blinking lights on my le Cube 185
I had a similar problem where both Small and Large cup buttons on mine blinked intermittently. I did a reset of the large and small cup flow levels based on the following and it seems to work fine now:
1. Switch off power 2. Press and hold Large cup button 3. Switch on power while still holding down large cup button
See if that solves your problem.
Aug 24, 2009 | Nespresso Essenza C100 Espresso...
Aug 20, 2007 | Nespresso C190 Espresso Machine
Nespresso C190 Espresso Machine Logo
190 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
