Question about Rinnai Heating & Cooling
Rinnai REU 58e installation manual - Rinnai Heating & Cooling
  • 1,420 Answers
Try w.ww.rinnai.us then look under library . Or wwww.rinnai.au
Posted on Apr 10, 2011
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
Hi there i have an old rinnai tankless water heater model # REU-502 and i need a new thermocouple (pilot won't stay lit after i hold it on for ever)i have the original manual but no one locally can he
That unit has a 5 year warranty on the parts that you are talking about. The unit also is proprietary and you have to contact them for service.
Mar 31, 2014 | Rinnai Heating & Cooling
I have a old Rinnai gas water heater Mod REU 55 FTB, after a year not in used, now the gas can not flow, how is the solution ? Thx
If it hasn't been in use for a year or so there could be a couple problems. Sometimes the gas dissipates from the line after an extended period of inactivity. You may need to try several times to light the pilot or the line may need to be purged. Also, if there's gas to the appliance and the pilot will light but not stay on the thermocouple is bad and should be replaced.
Feb 14, 2013 | Water Heaters
Im looking for the best option to get a Rinnai unit that would supply water at 30c or just below. i was going to buy the REU 55RT but looking at the manual i dont know how low the temp can get
Most tankless are preset to 120 degrees F.
30 degrees C is 86 degrees F.
If you want adjustable product, then tankless is not best choice.
Tankless are high tech gadgets with multiple interrelated parts controlled by sensors feeding information to control board. Everything internal and external has to be working correctly for tankless to work at all.
Most tankless brands do not suggest self-install, or self-adjustment, or any adjustment for reason given above.
You would be better off buying typical tank-type gas or electric and then thermostat adjustment is simple.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
http://waterheatertimer.org/pro-n-con.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 23, 2011 | Rinnai Digital Remote Water Heater Control...
Ignition problem: I have a gas hot water system: RINNAI CORPORATION; MODEL:REU-2008W-A the panel display temperature as 40C, when open the tap, the temperature display dropped to 12C, and no...
This is an error code 12, not 12 degrees. You have a short on your low voltage side by the sounds of it.. First disconnect the controllers inside the heater. Turn of the power first, 2 screws top and bottom to take the frnot panel off. Follow the low voltage wires (not the power point ones) to the PCB on the ride side and disconnect them both. Panel back on, power on and try the heater again. If this fixes it you have a short circuit in the controller or the wires leading to it. If not the most likely short circuit is on the thermal fuse which loops around the heat exchanger. This will need an expert, Perth has plenty north and south of the river. Give Rinnai a ring first, they have some good staff in Perth who might help.
Dec 02, 2010 | Rinnai Water Heaters
I need a service manual for a Rinnai Infinity 26 continuous flow hotwater system - REU-VR2626WG-AK Can you help me? Linda
I left Rinnai only about a year ago at a levle of State Service Manager. I had been asking for service manual for for many, many months. Basically as far as I am aware there is not a service manual for the WG. If you google Rinnai Infinity 26 manual you can get a PDF from the Rinnai NZ sales site but his dates baack to 2003. Unfortunately there are major changes to some of the components but it might be better than nothing. Just don't use part numbers, and you might find bits to check that now have voltage and resistance differences. Send a message to Rinnai complaining, I encouraged people to do so even when I worked for them!
Aug 26, 2010 | Water Heaters
I "think" I have pinpointed the problem but want confirmation before I buy this part. the sequence of "lighting " the pilot is working fine and the water flow is circulating as it should. when I "turn"...
To keep the Pilot running... TYPICALLY the instructions say hold the pilot down for 30 seconds to allow the thermocouple to assume control... If extending that 30 seconds a wee bit does not work and your "pilot" keeps going out...
You have indeed found your "trouble"
The obvious defferences being length (first
(see generic parts below)
Follow the instructions on the replacement &
- DO NOT overtighten...!!
https://www.bing.com/search?q=thermocouple+rinnai+REU-95GS&qs=n&form=QBLH&sp=-1&pq=thermocouple+rinnai+reu-95gs&sc=0-28&sk=&cvid=AE29392FA0A049CDA62B934C932F13A7
Generic
Amazon com replacement thermocouple
Carnac the Magnificent
Mar 11, 2017 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
239 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
