Question about LG Washing Machines
Wd80250np the lights are flashing 1st and second row temperature and pre wash
    Brigadier General:
  • 6,277 Answers
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 11, 2011
Long wash & spin light come on with contiuous beeps, every second... tried turning power off then on etc Machine starts up, water fills & drains but the alarm coms up after time... Any ideas?
Hi just read your posting.From the information in your posting the lights that are lit when the machine beeps are,On the row of 8 lights starting from left to right ,the 1st and 8th.Is this correct?Please reply with additional information and I am sure I can help.Looking forward to your reply.
May 18, 2011 | Fisher and Paykel Washing Machines
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
My 1 year old washing machine is not working apart from from a couple of lights flashing abd beeping
Hi just read your posting.Now when your machine is beeping a series of lights will light up.They will be in a row of 8 lights.Starting from left to right which lights are lit,Is it the 2nd and 4th or the 1st and 7th ---etc---?Also please supply the model number which is on a sticker which is located on the back of the machine ,top left.Looking forward to your reply.
Sep 09, 2010 | Fisher and Paykel Washing Machines
The washing machine fills with water but then appears like it struggles to spin and then it stops attempting to spin, then starts to beep and flash lights. the lights that flash are the middle green...
Hi just read your posting.Now the lights that are flashing are an ERROR CODE .On the row of 8 lights that these lights are flashing which ones are flashing,starting from the left to right of the row is it the 2nd and 3rd and 8th or the 1st and 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Jul 30, 2010 | Fisher and Paykel Washing Machines
When i switch on my fisher an paykel smart drive model gw601-f, all the lights come on for a few seconds, then just the top lights flash back and forth
Hi just read your posting.Please reply back and tell me which lights are flashing.This is an Error Code and it will let me know what is wrong with your machine.On the row in which the lights are flashing ,starting from the left to right which ones are flashing,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply back with additional information on the lights and I am sure I can help you rectify this fault.
Jul 21, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel WL80T65D washing machine won't fill or spin
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
Jul 10, 2010 | Fisher and Paykel Washing Machines
Linksys DGS-1224T Flashing Lights/No connection
I think its a DLINK-DGS-1224T.. Check also is the power light is flashing?
Try to hard reset the router and flash the firmware. You can firmware from DLINK.
Hope it will help you..
Oct 08, 2008 | Computers & Internet
Pre wash not happening
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
Jun 13, 2007 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
138 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
