Question about Nextar MA933A MP3 Player
What is the upc? - Nextar MA933A MP3 Player
  • 7,482 Answers
UPC=Universal Product Code
Wikipedia says:
The UPC encodes 12 decimal digits as SLLLLLLMRRRRRRE, where S (start) and E (end) are the bit pattern 101, M (middle) is the bit pattern 01010 (called guard bars), and each L (left) and R (right) are digits, each one represented by a seven-bit code. This is a total of 95 bits. The bit pattern for each numeral is designed to be as little like the others as possible, and to have no more than four consecutive 1s or 0s in order. Both are for reliability in scanning.
Since S, M, and E all include two bars, and each of the 12 digits of the UPC-A barcode consists of two bars and two spaces, all UPC-A barcodes consist of exactly (3 × 2) + (12 × 2) = 30 bars.
The UPC has only numerals, with no letters or other characters. The first digit L is the prefix. The last digit R is an error correcting check digit, allowing some errors in scanning or manual entry to be detected. UPC data structures are a component of GTINs (Global Trade Item Numbers). All of these data structures follow the global GS1 standards.
Posted on Apr 10, 2011
Need product for upc 060538801519
That number does not come up in the UPC database.
Double check it to verify it is the actual UPC number, and not a particular retailer's or manufacturer's item number.
Nov 04, 2014 | Computers & Internet
Tip
How do I create a UPC Code Labels?
<p>Universal Product Code (UPC barcode) is numeric, computer-readable tags used to track products in a store or warehouse. GS1 is the only body that the numbers of the original UPC barcode can give companies in the United States. The acquisition of authentic bar code numbers for your UPC labels, you need a partner and GS1 bar code numbers for your payments. <br /> <p><br /> <p>1. Suppose your company expects annual turnover, number of products that will sell that require UPC bar codes, contact information and your business. <br /> <p><br /> <p>2. Go to the site of GS1 and GS1 U.S., apply for the program Connections partners. Pay your membership online by credit card, or follow the instructions as part of an application to send a check. <br /> <p><br /> <p>3. Log on to the GS1 site a day after your membership is processed to determine your company's prefix number. This number is unique to your company and is an essential part of your bar code numbers. His company prefix, the first 2-6 numbers of the barcode. Download your number of UPC bar code on the site of GS1. <br /> <p><br /> <p>4. Print your labels, UPC bar code at home or third company to print. You can choose to print bar codes directly on the product packaging. <br /> <p><br /> <p>5. Make sure your UPC barcode labels and height requirements for the color of GS1 distribution of your product needs. Labels that do not meet these requirements cannot be read by machines, bar code scanner. <br />
on Jun 26, 2011 | Computers & Internet
UPC code85948500222
Hi. I'm not sure if this will help you, but I found this website:
UPC Database Item Lookup
According to this website:
"Enter the all digits printed on the UPC bar code, including any numbers to the right or left of the bar code itself, even if they don't line up with the main row of numbers. This should be 13 digits for an EAN/UCC-13, 12 digits for a Type A UPC code, or 8 digits for a Type-E (zero-supressed) UPC code. Anything other than 8 or 12 digits is not a UPC code! (And just because it's 8 or 12 digits doesn't mean it is a UPC.) You must enter every digit here.
If you have a barcode scanner that outputs plain numbers, you should be able to use it to enter the UPC number here."
So, apparently you need more digits to complete the bar code #. But if you have the full barcode, you should be able to enter it on the website linked above, and find the image of the frames that you are looking for. I hope this helped. Thanks!
Oct 23, 2014 | Datalogic QuickScan QS6000 Plus Bar Code...
Walmart product codes
I've not been able to locate this as a valid UPC code. Are you sure you've enterted it correctly? You can look up many UPC codes at http://www.upcdatabase.com/pleaselogin.asp
May 24, 2014 | Computers & Internet
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from support.symbol.com.
The P370 is NOT supported by the newer 123Scan2.
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
Deleting upc codes from a Sharp XE-A505 cash register
Hello there,
To delete UPC codes, please refer to this portion of your manual.
Hope this answers your problem. Goodluck!
Sep 25, 2009 | Casio Parts Cash Register PC Desktop
UPC drum stuck
My co-worker managed to get the UPC drum back in by prodding the toner cartridge (which was too close and thus blocking the UPC drum) slightly to the side. After the UPC drum was back in she closed the printer, went through the menu that allows the toner cartridges to be moved for removal/replacement. She removed the toner cartridge, got the UPC drum out, removed the transfer belt, cleaned it and put everything back into place. My printer is now back in working order! And I owe her lunch, big time!
Should I ever have to do this again, I will remember to remove one toner cartridge first.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Voyager 9520 10 digit UPC
The last digit should be a parity Digit (used for error checking)
you may be able to clear this using the settings barcodes in the user manual
Mar 31, 2008 | Metrologic Instruments 9520 Voyager
Nextar MA933A MP3 Player Logo
154 people viewed this question
Top Nextar Audio Players & Recorders Experts
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Joseph Hoffmann
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
