Question about Motorola FV200AA GMRS/FRS 2-Way Radio Walkie Talkie with 5 mile Range
Unit won't stop changing channels
My kids have a pair of these walkie-talkies and one of them has developed a quirk. When you turn it on, it starts changing channels, and it won't stop until you turn it off -- unless it notices something happening on some channel, when it will stop there ... almost like a police scanner ... but it won't stay there, or give you control: as soon as you press a button, it starts scanning again.
I thought of taking out the batteries and seeing whether the unit would reset itself when new batteries were installed -- but it's rechargeable. And there doesn't appear to be any other way to reset it.
Any ideas? Thanks for your help.
  • periculum Aug 07, 2008
    Hi! Thanks for this; we're getting there.
    The radio doesn't have a Z key, just four buttons (menu / plus / minus / musical note) on the front, and a push-to-talk button on the side.
    We don't have the manual anymore, unfortunately. That was the first thing I looked for. I have also tried Google, looking for [Motorola FV200AA "user manual"] and variations on that theme. Didn't find any user manuals but I did find you!
    (I think it's an FV200AA because it matches pictures I've seen on the net, labeled as such; but there's no model number visible on the unit, so I guess I could be wrong -- but I hope not!)
    It seems to me that scan mode must be activated / deactivated by a combination of keys (in the absence of a Z button, how else could it be done?) and I have pressed keys in every possible combination (there really aren't too many) ... none of which made any difference.
    So now I guess it boils down to whether anyone can find a manual.
    Thanks again for your very kind assistance.
    The search for a manual can be over now. I ran the radio until its batteries were empty, then recharged it, and when I turned it on again -- poof! -- it did a reset and now it's back in normal mode.
    Thanks again and best wishes
Thanks everyone, I was going CRAZY
my kids have the other ones (2) at the park
I don't know what I would have done
Thanks from alaska
Posted on Oct 02, 2008
  • Motorola Master
  • 1,654 Answers
Your radio will recall the last setting you were on when you shut the radio off. So when you turn it on again, it will be in the same mode.
Your radio is stuck in scan mode, either by being programmed by the user that way, or by the button being stuck. Most-likely it is from someone playing with the unit and turning on scan. On some Motorola models scan is depicted by a little button with a Z on it. If this is the case press the Z button and then turn the radio off. When you turn it back on you should be good to go.
Otherwise, Get out your owners manual and look for directions on shutting off scan, or resetting the radio to the factory default settings. If you do not have the manual, do a quick google search for your radio model and the words "user manual". If you don't find one, post here again, and some of us will try to locate one for you.
Posted on Aug 07, 2008
I cannot get my bellsouth walkie talkie model 2290 to unlock from a channel
The manual says to press and hold the MODE button for 5 seconds turn on or to turn off the LOCK mode. When locked, it prevents you from accidentally changing channels.
Jan 05, 2013 | BellSouth 2290 Walkie Talkie FRS/GMRS...
Walkie talkies were working yesterday (gift from Christmas) and today the red power light is on indicating both working, but we can only get sound out of one of them.....any suggestions? brand new...
These walkie talkies are pretty simple to use. Turn on and turn the volume up and talk. So if you turn it on it is possible for there to be enough juice in the batteries to make the LED function but not enough to modulate (or talk) to the other walkie talkie. Have you tried to replacing the batteries with new ones yet? Sometimes recharge ables go bad and they are no good when you install them into your item. So make sure the batteries you installed are "new." And replace in both units. Should this not work, given the nature of the item and the age of those who will more than likely be using them, they break and soldier joints come loose. The back has a screw that is a specialty tool to remove. Outside of removing that and taking a look there is not much that can be done. Make sure to put at least 5 feet between the two radios to allow for good reception.
Regards, Tony
Apr 17, 2011 | Digital Blue LEGO Walkie Talkies
We have Motorola T4500 walkie talkies. One of the units keep searching and has a z in the upper right hand corner. How do I turn that off?
The Z means the radio is scanning some or all of the channels that have been programmed into it. One of the buttons on the radio should stop the scanning. The button is usually the same one that starts the scanning, and pushing it a second time will stop the operation.
Mar 19, 2011 | Motorola Walkie Talkie 2-Way Radio
Is there a way I can change the channel on my Walkie Talkie manually. I can't get them both on the same channel.
On the Motorolas you have to press the menu button until your current channel flashes. Then press the plus (+) or minus(-) sign to change the channel. 21 is a great channel and you can get distance on it.
May 10, 2010 | Motorola Walkie Talkie 2-Way Radio
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Oct 23, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
Walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40 channels.
Cell phone
can communicate on 1,664 channels or more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
Feb 04, 2008 | Motorola Walkie Talkie 2-Way Radio
Motorola FV200AA GMRS/FRS 2-Way Radio Walkie Talkie with 5 mile Range Logo
399 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
