I've put a load of washing on and the door is still locked after it's done and so i thought if i put it on again it would sort itself out but it's not doing anything now and the door is still locked plz plz help me
Sounds like your not waiting the time of 2 -3 mintutes then the door magnet will release the door
Posted on Apr 10, 2011
Door stuck closed after wash is done
If the water in the machine is above a certain level a fail safe on the door lock will not allow it to be opened. Check the filter, make sure the machine has completely drained. Obviously, there may be a problem with the lock itself but try this first.
All the best
Mar 20, 2013 | Bosch Axxis WFL 2060 Front Load Washer
I have an IQ touch front load washer. lately I have noticed a mildew smell coming from the clothes and drum after washing. i have followed the manual and completed the refresh and comlete cleaning...
Water can remain in ANY washer after the load is done. With a top-loading washer, it's easy to leave the lid up so that the water evaporates. With a front loader such as yours, however, the open door can take space in your laundry area, so we usually close the doors. I suggest that you take a dilute solution of chlorine bleach and water and put it on a disposable cloth and wipe down the inside of your washer as well as the areas around the door itself and the part of the washer that the door closes onto. Once you've done this, leave the door open until the smell dissipates OR overnight. If you will get into the habit of leaving the door open for a couple of hours after you're done with your laundry, you will probably solve the problem.
I really hope this helps. If it does, please come back to Fixya and rate my solution.
Jul 09, 2011 | Electrolux Washing Machines
Affinity washer door lock shuts off. I put a new door lock in and after 20 min it does it again.
Wait until the washer gets done, and then try unplugging the washer for fifteen minutes.
May 06, 2011 | Frigidaire Affinity ATF7000E Front Load...
Duet front load washer door locked & will not cont wash cycle
you can use a wet dry shop vac and attach it to the end of the drain hose and remove all the water in the unit this should unlock your door then you can check the drain pump for anything that may be restricting or blocking the drain pump
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't do anything but hum....no lights on but door locked light
I cant understand what you are saying,your spelling didnt help much.If you re-write it again i might be able to help.
May 28, 2010 | GE WSXH208A Front Load Washer
Maytag Neptune washer front load- Can't open the door
Take out the bleach and softener tray (it just lifts out, angle it a little) and unscrew the 4 bezel screws and take out the bezel. You will find a red or green plastic pull line that is supposed to release the door. You may have to "man-handle" the door a bit and pull hard on the line before it will release. Once you work on the door release mechanism (I had to replace the wax motor again, even though it was the "upgrade" black plunger type) I recommend shooting a little silicon spray on the white plastic moving parts of the locking mechanism to get them to move more easily.
This is true on a Maytag Neptune MAH3000AWW front loading washer. Mine is 11 years old, and had the initial wax motor work done at 7 years.
Jun 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Electrolux front loading washer - door is locked, won't unlock
I have an Electrolux front loading washer. I just got done washing a load of laundry and the door will not unlock. I tried washing it for a second time thinking maybe it would open again. No luck.
Nov 09, 2008 | Washing Machines
Door won't lock and washer won't start
means your doorlock is either not alligned any more or you need a new door lock. Not overly easy to put in but it can be done.
Door latch can be obtained here and drawing is HERE
Jun 16, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
