Question about Canon Office Equipment & Supplies
I Just replaced the toner in my CANON IR1600 PHOTOCOPIER and now have the Error code E100. I put the old one back in to see if it was different but it still said E100. How can I fix this? Thanks
Hi carolyn ,
I am a professional canon service eng . My Name Is D K Kumar . e100 is not related to toner at all . it is the indication that the develper unit has not been detected . remove the left side cover . you will be able to see the top of the develpoer unit. On the left top portion of the developer unit u can see a white coloured accuvator . it is a small white plastic piece ..whhen the side door is closed te white piece should get pressed or should move forward . if the moving action is not happening then the m/c will give u E100 error. in your case the reasons /problem could be :
!) The spring connected to the white plastic accuvator is missing or spring action is not happening.
2) the white accuvator it self is broken or missing.
3) the plastic stick /piece which protudes from the side door and pushes the accuvator is broken.
4)lastly you have not closed the side door properly or not closed at all.
Carolyn if u r able to understand my above tips thn u can do it your self , if not call a your local canon enginer.
best of luck God Bless u
P.S. Carolyn if my solutions have helped u then i request u to kindly reply to me at my enail id: narkumar81@rediffmail.com
Posted on Apr 10, 2011
I have replaced a new toner for my machine and still indicating add toner machine model is canon ir1600
Posted on Oct 29, 2012
  • kanwarjeet Jan 11, 2013
    May be the sensor which detects the toner is not is not working.Replace it.
How do I solve a system error E000 on canon iR1600 photocopier?
First you need to clear that error from service mode. If problem persist replace the fixing unit
Jun 15, 2015 | Canon Office Equipment & Supplies
How can i solve the problem of System error E100 in a Canon iR 1020 photocopier?
You should have a PDF Owner's manual on the software install disk. Troubleshooting section should say what the error is and what to do to fix. Or try this:
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR1020
Apr 02, 2015 | Canon Office Equipment & Supplies
How do I clear error E100 on my Canon GP215 photocopier? The paper keeps on jamming continuously.
Odds are you will need to replace the fixing unit. The error code deal with the fixing unit not heating up to the correct temp.
May 22, 2012 | Canon Office Equipment & Supplies
Canon copier iR1600 machine giving code E100
A E100 is the laser shutter is not opening. There is a spring that most likely came off. It is actuated by the door closing. You may have to get a service technician to repair it for you.
Jan 24, 2011 | Canon iR 1600 Laser Photo Printer
Want to correct a system error E000 on canon IR1600 photocopier
E000 indicates a low temperature problem in the fuser unit.
  • Check the fuser for any jammed paper and remove it
Check and replace with spare part if needed:
  • the thermo lamp,
  • the thermistor in the fuser unit
A code reset is needed:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 PRINTER, press OK
  3. Go to #4 PRINTER RESET, press OK
  4. YES = (*)
  5. Power cycle the unit.
Jan 05, 2011 | Canon iR1600-2000 PS
My copie canon ir1600 give problem code E100?
check the drum unit, does it fit well? if not replace it else laser unit is faulty. replace it
Dec 30, 2010 | Canon Office Equipment & Supplies
Sir,My IR1600 dosnt fuction or now dosenot start to work
Hi, do you have an error message like E100 ? Please be specific.
Mar 22, 2009 | Canon imageRUNNER 1600 Laser Printer
SYSTEM ERROR E100
Hey
How can I solve this error code(IR1600) on my canon copier by myself?
Nov 27, 2007 | Canon imageRUNNER 2000 Copier
701 people viewed this question
old marine
old marine
