Question about Fuji Cameras
I've got a problem with my camera which is the fuji film s1 pro then when i started to click the shutter there is an blinking error message..it cannot capture photos what should I do?please help me...
  • 747 Answers
There are several things that may cause this. If the previous pictures were downloaded to a computer it will require being formatted in the camera. The memory card is full and can not write any more pictures to the memory card. You may have just purchase a new memory card and it needs formatting before using in your camera. You may have purchase a new memory card that is a higher capacity then what your camera firmware is capable of writing too.
For example my S2 Pro worked great with a 1gig card but on a few shoots I needed to change memory cards so I purchase an 8gig and it didn't work. What I needed to do was go onto the Fuji site and download an updated version on the camera firmware which allowed me to use a 4gig memory card. I have more then one camera so the 8gig was used in another "newer" camera.
Hope one of these is the solution and you can get back to taking pictures
Posted on Apr 10, 2011
I haven't heard back yet. Alol I needed to do to correct err message was replace AA batteries. Please send my operators manual.
Please CLICK HERE TO DOWNLOAD the operators manual for Fuji FinePix S1 Pro Digital Camera .
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site.
Oct 11, 2011 | Fuji FinePix S1 Pro Digital Camera
Problem that my S1 Err each time i put my lens i can only used on M other like A,P,A cannot be used tk
Your Finepix S1 has wear on the drive sequence, that produces the error.
Fails to load the shutter.
You must obtain these parts attached except that the belt and motoradgubitosi_4.gif.
Mar 20, 2011 | Fuji FinePix S1 Pro Digital Camera
When i turn on my fuji polaroid cam, there is an "E" error message. I can't take any polaroid pictures with it altho the polaroid cam is loaded with film. Please help. Thanks
First, remove the remaining films from the camera. (while your camera is switched off) Second, press on both the shutter button and the power button at the same time. (to reset) Third, reload a new set of polaroid films into the camera.
Hope it helps!
Dec 26, 2010 | Fuji instax mini 7S Film Camera
My fuji instax mini 7s has an error message on the screen. It blinks "E" and does not allow me to take any pictures. The instructions and manuals that came with package are all in japanese and i...
Firstly, remove the remaining films in your camera (while the camera is switched off) Secondly, switch on the camera. Press the power button and the shutter button simultaneously at one go. (to reset) Thirdly, reload a new set of polaroid films. Hope it helps!
Nov 05, 2010 | Fuji instax mini 7S Film Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Fee flashes even though apeture ring is set to
I have the same prolem. I think it has soming to do with the Meter coupling lever , it protrudes top of the Nlkon F-mount on the front of your camera. it may be need of repair
Sep 12, 2009 | Fuji FinePix S1 Pro Digital Camera
Fuji FinePix S1 Pro Digital.
I strongly recommend you use a memory card reader to solve this problem.
The cause is likely a bad USB cable, USB port on the Camera, or low battery.
A USB memory card reader will work around any of those causes.
Jul 20, 2008 | Fuji FinePix S1 Pro Digital Camera
Hello guys fuji film s1 pro problem
From the Fuji S1 Manual:
F-- (Flashing) or (lit in M Mode)
Cause:
The lens mounted is not a Nikkor lens with built-in CPU or no lens is mounted on the camera.
Solution:
Use a Nikkor lens with built-in CPU (excluding IX Nikkor lenes). (Note that pictures can still be taken in M mode.)
Jun 06, 2008 | Fuji FinePix S1 Pro Digital Camera
Err message
This problem is caused by the plastic memory card door.
There is a door that hides the memory card on the back of the camera.
The door has a small plastic part on the left side that when the door is closed fits inside the camera.
When the door is open this part is exposed. It is right next to the "^" in "^ PUSH TO EJECT"
If you place one drop of superglue on the top of this little plastic part of the door(when open) and let it dry overnight(LEAVING THE DOOR OPEN OVERNIGHT.)
This will slightly build the plastic up about .05-1mm.
The problem is caused by the plastic part being about 1mm too small, liking resulting from normal wear.
I have tested this, and it seems to have resolved my issue with the S1 Pro I bought on e-bay
John C. Vincent
yellowcaseartist.com
May 01, 2008 | Fuji FinePix S1 Pro Digital Camera
Fuji Finepix S1 Pro fE E blinking when turned on?
Might Help:
Notes on G-type Nikkor and other CPU Nikkor lens
The G-type Nikkor lens has no aperture ring; aperture should be selected from camera body. Unlike other CPU Nikkor lenses, aperture does not need to be set to minimum (largest f-number). CPU Nikkor lenses other than G-type Nikkor lens have an aperture ring. Set the lens aperture to its minimum and lock. When the lens is not set to its minimum aperture setting and the power switch is turned on, "fEE" blinks in the control panel and viewfinder and the shutter cannot be released.
Nov 09, 2007 | Fuji FinePix S1 Pro Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
