Acer AOA150 bricked when trying to re-flash BIOS. Symthoms: during crisisdisk procedure, pushing Fn+Esc and pluginAC, only battery led lits, and power-on led lit for a second.then nothig happens. USB dongle lits also (continously). I thing I need to replace the BIOS CHIP (got an spare Motherboard from an spare parts shop), but I don't know Whic IC is the BIOS CHIP. Motherboard is DA0ZG5MB8F0 REV G (sata disk version) My email: estebanjle@gmail.com THANKS in advance
wealthwise
  • 111 Answers
SOURCE: Acer Aspire not booting
I'm inclined to believe something is going on with the DVD drive, perhaps a I/O cable or driver issue, it just seems like what you said about the drive sounding like it's trying to read is a clue, what I would try if you have not already ,is since you said you can get to get to the Bios usually the default for boot sequence is CD/DVD drive first unless you change it, see if you can change the boot sequence from DVD drive first to HDD first and see if you can bypass it, then it might just boot, if that works then that was the cause,I see no other reason why the Drive should be trying to read other than the boot sequence. if not then it might be more complicated and could be a hardware issue somewhere,
Hoep this helps.
Posted on Dec 05, 2008
rubydu
  • 102 Answers
SOURCE: Same problem, ASPIRE 3680 is dead or something near
laptop mother board is get short its's supply ic is faulty repair this
Posted on Jul 21, 2009
  • 3 Answers
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Posted on Sep 28, 2009
sinam777
SOURCE: Cannot install ANY Windows OS on Aspire One AOA150
Take out HDD (google around - there are videos explaining that, and service repair manual for Aspire One), connect to another PC, install and open up Active@ Partition Recovery, select this HDD, go through menu - Tools-Fix MBR (Create Typical MBR), in first popup window select Yes (agreing to fix MBR), in second select No (agreing to fix MBR and delete all partitions on HDD, because Yes- you agreing to fix MBR without deleting all partitions, but be sure you back up your data, if you have any). Then with Acronis Disk Director wipe this HDD. Then repeat fixing exactly the same with Active@ Partition Recovery. Go back to Acronis Disk Director, create partition - primary and set it active. Format with NTFS (if you want to Install XP or later, and if its not SSD). Then shut down PC, take out your HDD, back to the netbook. Now you can install any Windows if you haven't other problems with your netbook. Better try installing with external DVD drive, because USB drives sometimes fail.
Posted on Jan 25, 2010
rahimhd
  • 31 Answers
SOURCE: acer aspire 4315 Blank Screen!!!!!!!!
You need to Revive the bios back.
Search for Acer bios revive in google
Posted on Feb 22, 2010
My net acer zg5 AOA150 doesn.t go. He start only the light "on" but it doesn't go
you need a flash drive fat32 formatted,download the bios update from acer website.copy the flashit.exe & 3114.fd to flash driverename 3114fd to ZG5IA32.FD.insert ur flash drive to the right side usb port. turn on power while holding Fn and Esc key don not release the combination key until u count of 7 sec, when light is on push again the power button then release.it will blink in a minute and the light turn off, don't do anything until it restart. just relax it takes a minute.if you can't download the file e-mail me @ fccaole@yahoo.comgood luck guys! wait for 7 second to release
Jul 30, 2011 | Acer Aspire One AOA150-1784 Netbook
My acer computer has the blue power light on but the screen is blank. I don't know how to get it to turn on all the way.
sounds like the common BIOS flash fix.
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Nov 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
My screen is black what shall I do?
Nov 28, 2010 | Acer Aspire One PC Notebook
Won't turn on. On button glows green and harddrive light flashes and goes out. On button continues to glow. If I hold the on button down 5 seconds it goes out. It was working fine, I turned it off and...
*This method only applies to Aspire ONE A150 only
1) Format USB memory stick with FAT file system.
2) Download BIOS for A150
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=Netbook&Step2=Aspire%20One&Step3=AOA150&OS=X01&LC=en&BC=Acer&SC=PA_7
3) Extract all files the downloaded file and place FLASHIT.EXE and BIOS file onto the memory stick
4) Rename BIOS file to ZG5IA32.FD
5) Turn netbook of, with power AND battery connected
6) Plug in memory stick with BIOS file and Flasit.exe
7) Press and hold Fn+Esc the unit will go on, hold until power LED is flashing then release keys. If it does not flash, then release and press power button once.
8) You'll notice the LED of both the usb memory stick and the power LED will flash together.
9) After a few seconds the flashing will stop and the unit will reboot or switch off completely.
^^ this is a copy paste from my own solutions
May 13, 2010 | Acer Aspire One AOA150-1570 Notebook PC
My acer aspire 4315 laptop screen goes dark
ASPIRE ONE BIOS FLASH RECOVERY
http://support.acer.com/drivers_download.aspx
http://blog.shimpossible.com/2007/07/18/white-screen-of-deat­h/
Mar 05, 2010 | Acer Aspire 4315 Notebook
Black screen acer aspire 4315, changed screen & inverter but still no joy any help please.
If the screen is black and the power light & fan still work....try this:
Jan 19, 2010 | Acer Aspire 4315 Notebook
Power is on but i get nothing but a black screen
Jan 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
My ACER Aspire One ran out of battery power so it was plugged in to recharge and left alone for a couple hours. When I returned to it and tried to turn it on...nothing. The green power light comes on and...
You can find the BIOS download here:
Jan 17, 2010 | Acer Aspire One PC Notebook
My acer netbook has no vide0? it just went out! it is out of warranty; only had it for a little over year; for acer to fix it I might as well buy it all over! Please help if you can???? I need the files...
Jan 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer not work
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Dec 11, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
