Question about Electrical Supplies
No spark hi i have a wizard lawn tractor and i cant get spark it will turn over but no spark i checked the coil and the alternator and the fuses still nothing do you have a wiring diagram for this model # ayp7134a99
    Sniper:
  • 120 Answers
Make sure you are getting spark from the coil. Then connect the coil wire to the distributor. Then check a plug wire for spark by grounding it with a screw driver. If you are getting spark from the coil, but not from the distributor wire there could be a wire broke in the distributor.
Posted on Jun 04, 2009
Craftsman lawn tractor
you may have a safety switch that has went bad or came unhooked. unplug and test for continuity. also under the hood you will see a fuse, check to see if that has blown. if all that is good you may want to unhook the coil try to start it and see if it has fire. it is possible the coil has went bad. hope this gives you an idea where to start
Aug 16, 2013 | Garden
What is the purpose of the coil charger
not sure what you mean by a coil charger. if you are referring to the coils under the flywheel, that is the equivalent of an alternator. the actual ignition module or coil doesn't have a charger. the alternator has nothing to do with the ignition module and the color of the fire. there is nothing wrong with an orange colored spark unless you have an HEI module at which point a special spark tester is required
Mar 28, 2013 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
I have a craftsman riding mower that will not start. Model No.917258473 Serial No.062597C003426 It did try to fire over before it did nothing,I have installed a new solenoid & starter and tried to jump...
First I would check the spark plug. Remove the plug and with the high tension lead fitted earth the plug against the engine, turn the engine and see if the plug is sparking. Hold the metal part of the plug and you wont get shocked. If you have a spark then your problem is fuel, you will have check the carb. and filters. If you have no spark , it could be the wires or the high tension coil.
Apr 26, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawn tractor won't start no spark an I have aready replaced the electrical control circuit board. It is a LX277 lawn tractor year 2000 I think. After I replaced the circuit board It still did't start I...
May be the coil is bad. have you checked the spark plug? If there is gas and spark then it will have to start.check the circuit breaker points. is there current in the cb points?
Sep 10, 2009 | John Deere Garden
I cant shut off my lawn tractor with the key
I actually had the same problem with my tractor and it turned out to be that I had to run a second ground wire (ground to a separate point) that forces the coil to ground). My suggestion is to remove the flywheel cover and attach a wire (at a different point) to the coil and then start the tractor and when you go to shut it off. Turn the key and then just find a metal point on the tractor to touch the wire to and hopefully the tractor will shut off.
Jul 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HAVE A JOHN DEERE 318 LAWN TRACTOR, CHANGED POINTS AND CONDENSER, WON'T TURN OVER, TRIED STARTING FLUID IN CARB AND NOTHING. CAN IT BE THE COIL AND HOW DO I CHECK? THANKS
Check the coil impedance on the primary and secondary side. You'll have to disconnect the battery negative cable so you don't short something out. Unplug the spark plug wires and the two sets of smaller wires connected to the primary side of the coil. The primary coil reading should be between 3.7 ohms and 4.6 ohms while the secondary (spark plug side) should be between 34.2 k-ohms and 41.6 k-ohms. If the resistance values you measure are outside of these ranges, you need to replace the coil.
May 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No spark
hi is this a point less ignition or electronic? check that your ground wire from ign. coil is not grounded causing no start.( last ign coil shot) good luck.
Apr 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
No spark on lawn tractor
have you bypassed the ignition switch?? if you by pass that switch and you get spark you know its the switch
Sep 28, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Electrical Supplies Logo
215 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
