Question about RTO PasLode 900420 Impulse Framing Nailer
Gun will not work, battery charged as soon as you put it in the gun it goes red.
Hi it could be your gun if it is flashing red&green this means theres a fault with the gun if it is just red try cleaning the battery treminals with a bit of sand paper some times they get a bit dirty and dont get enough contact with the gun hope this helps
Posted on Apr 20, 2011
Paslode 350i first fix nail gun. Charge both batteries (1 is brand new). Put battery into gun and fire. Im lucky to get one nail from it before gun shows up red.
Sounds like either the battery is bad, or since one is new its possible the contacts in the gun are not making proper contact. Are you sure your charger is working as well ? If you have a volt meter check that the battery does have a charge on it.
Oct 10, 2016 | Air Tools & Compressors
IM350 when battery inserted flashes green then goes to red. Tried battery in other gun and works ok. Tried full charged battery (green in other gun) and led goes red in this one. Measured voltage at 6.74v....
Check the battery contacts in the gun...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Gun will not fire, battery is charged & good ??? model #IM25011 part # 900400 Bob
problem solved - battery charger indicated that battery was charged with green light on, took battery ouit & placed it back in charger & red light came on after doing this three times the battery was fully charged and the gun worked fine.
thanksBob
Jan 29, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My nail gun when i locate the battery to the gun it does not work
Make sure none of the battery contacts in the nail gun aren't bent, broken or missing. Try to rebend them out to make better contact.
Also make sure your battery charger is actually charging the batts as well.
let me know how it goes..
K
Oct 06, 2009 | Black & Decker Tools & Hardware - Others
The green light is on as though the battery is fully charged, however, when I start a cleaning cycle, it beeps and goes to red immediately without moving.
Remove the battery, hold down the POWER button for ten seconds, then put the battery back in and charge overnight. If it still tells you it's out of power as soon as you start it, it's time for a new battery. http://store.irobot.com
Aug 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
My Casio Exilim EX-S880 wont charge. when i put on the charger the red light blinks but it is not charging.
I had this exact same problem. Here's a solution. I had to do it about 7 times and others on Amazon said they had to do it about 20 times. But it does work! My light is a solid red as we speak! Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Jul 16, 2009 | Casio Exilim EX-S880 Digital Camera
Red light keeps comming on and battery goes dead.
Alternator and stator....put a voltmeter on the battery - it should read about 12- 13 volts. Then start the bike.... when its running, the volts should increase.... if it doesnt....your charging system isnt working.
Jun 27, 2009 | 2006 Harley Davidson XL 1200 R Sporster...
Fan not working
If the battery is flashing red, the battery is not charged or on a minimal charge.
Have you attempted to recharge it and does it still give you this symptom?
K
Jun 21, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
My NEW Blackberry 8310 won't charge! Red light flashes just once.
get a message saying my USB is not sufficient enough to charge phone ???? It works on other computers just not the one I need it to work on.
May 09, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
RTO PasLode 900420 Impulse Framing Nailer  Logo
130 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
