Question about Jmlab Electra 905 Speaker
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed anything. When I play a CD, the humming noise remains. When I turn the volume up, the left speaker makes a loud banging noise. Help! I suspect the left power amp is faulty. Any ideas?? Thanks.
    Top Expert:
  • Jmlab Master
  • 75,178 Answers
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Posted on Apr 10, 2011
  • rossglamont Apr 11, 2011
    Thanks gopakumarg, most helpful. Came to the conclusion it's probably a capacitor that's over-heated in the left pre-amp. Off to repair shop. Thanks again.
  • The Knight
    The Knight Apr 11, 2011
    Ok. Good Luck
I have a pair of KLH AV5001 speakers and I have them hooked up, there is sound but it's distorted and there's zero base, an instruction manual or any advice would be great, thank you.
Without knowing what they're hooked up too.. SOUNDS like your uder powering them, OR over powering them. Look at the back of the speakers the wattage is what your looking for, look at your amp, example: 1000w speaker running on 50w amp = not good.
Jul 05, 2016 | KLH Audio Players & Recorders
Celestion sr1
The physical fit is simple. They are designed to stack. How you drive them though is a different matter.
Depending on the vintage these are either an 8 Ohm load or a 4 Ohm load to the amp. Each pair needs to be connected to the appropriate driver/controller box for it's impedance. IOW, you need to run two sets of power amps, two controllers, and then two pairs of speakers.
BTW, just adding more speakers to a stereo power amp (or two monos) won't make the system appreciably louder. All you are doing is diluting the power output of the amps between four speakers rather than two. More speakers, sure. But each one now receives half the power compared to running 1 pair..
Aug 21, 2014 | Audio Players & Recorders
I have a JM Labs Cobalt SW800 subwoofer connected to a Yamaha RX-V2300. Recently during intense moments, esp action movies, the SW occasionally emits a loud pop; most of the time only one, but sometimes...
What you may be hearing is the speaker's guts bottoming out as it attempts to keep up with the amplifier, which may be clipping - a potential fatal thing to do to any speaker.
Maybe you should turn the volume down or run through the volume setup again and make the subwoofer equal in loudness to the other speakers and avoid excessive bass boost.
Feb 22, 2010 | Jmlab Cobalt SW 800 Speaker
Purchased 2 used sonance sonamp 260 for homewide speaker system (12 pair).line out from receiver into first amp powering first 8 pair.line out from first amp into second amp powers remaining 4pair.only...
I am assuming you are using the standard sonamp 260 not a 260x3
and that when you say you are getting sound on only 1 pair that means only on 1 side (left or right channel only?)
Are using a speaker selector box? you must to regulate the resistance (ohms)
if so first unhook all but on pair of speakers and see if both channels are working.
if they do your problem is in the speaker selector not the amp if no then check to see what the amp level is set to. These are the two small holes on the front right of amp make sure they are set about equal at around half way up.
If that doesn't work flip the RCA cables coming to the amp perhaps you have a bad cable if that doesn't work make sure your receiver (source) is outputing a stereo signal to begin with.
lastly 8 sets of speakers off 1 amp? that's pushing it.even with a high quality Niles or speakercraft selector that controls the resistance going to an amp I wouldn't go past 5 sets.
The right way to do it would be to use 260x3 or a sonance or speakercraft 12 channel amp.
Nov 04, 2009 | Sonance Sonamp 260 MKII 2-Channel...
I NEED FREE DIAGRAM OF CAR STEREO AND AMPLIFIER
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Jun 14, 2009 | Alpine CDM-7854
LCD directly to 5.1 Speakers?
No.
That is, not unless the speakers have their own amplifier built in.
The outputs you refer to them are line-out that need to be connected to an amplifier (also called a receiver).
When shopping for an amp, it would help to know what the maximum power the speakers can handle. Then, you can get an amp to match.
If you get an amp too powerful, you can blow the speakers up if you turn it up too loud.
Not powerful enough and you are not getting the most from your system.
You don't want to be running speakers at their maximum all the time either.
Apr 26, 2009 | Audio Players & Recorders
Can you run 200watt 6ohm speakers on the RX-V490
Hi I have just read the specs on about your Yamaha system and you cant run 6 ohm speakers to your amp. You have to impedance match the speakers and the amp otherwise the speakers will "blow". So you need some 8 ohm speakers, the wattage of the speakers doesn't particularly matter as long as they are not too weak or too powerful becasue the amp will drive the speakers no matter what but if the speakers are of a low wattage then the amp could blow the speakers if it is turned up too loud. The specs of your amp are given in the link below.
Yamaha
Regards
Rob
Nov 13, 2008 | Yamaha RX-V490 Receiver
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Jmlab Electra 905 Speaker Logo
606 people viewed this question
Top Jmlab Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jmlab Audio Player and Recorder Expert? Answer questions, earn points and help others
