Question about HP LaserJet 1320 Printer
Printer will not initialise and if i manage to make it initialise,it will stop after a short while
Konica minolta 211 ,aintainance book about developer initialisation procedure
Double check the developing sensor(TDS) connector then perform the following : [utility] [stop] [0] [0] [stop] [0] [1] go to [function] by using arrow key then [ ATDC Auto adjust] [ok]. wait for 2 mins then turn off/on the main power.
Sep 19, 2015 | Konica Minolta Office Equipment & Supplies
Printer motor runs continuosly, doesnt stops initialising
Unplug for 2 minutes & try it again. Reboot computer with printer on before trying to use. Still won't work send it for service.
Sep 16, 2015 | HP LaserJet 1020 Printer
After easing hard drive the machine will not power up but it won't go past the xerox home screen
Very little info to work with, but try turning on with [start], [stop] and [4] keys pressed down. Failing this try [start], [stop] and [6] keys pressed down. These are initialise HDD and format HDD respectivly.
Feb 11, 2015 | Xerox Office Equipment & Supplies
How do i initialise black toner for 2051c
No need to initialise toner.
When toner low, just replace the toner via the control panel.
Mar 27, 2014 | Toshiba e-Studio 2051C Multifunction...
External 3.5 inch IDE hdd encloser connected via USB is showing "device is not ready" when try to initialise it in the disk manager
Check the jumper settings of the IDE hard drive you have in the enclosure for compatibility in your setup. (Choices are Master, Slave and Cable Select).
Feb 06, 2014 | Computers & Internet
Hp 1007 laser printer on position but no initialise
just open the printer and check all the censor whether it got struck or any small paper will be inside.other than there is no problem in the printer
Aug 09, 2012 | Office Equipment & Supplies
How to enable Secondary IDE in NEC VERSA M400
I presume you have bought a secondary hard drive and want to fit it to your laptop.
Firstly fit the new drive, it then needs to be initialised, this can be done by running Control Pane, select Administrative tools, select Computer Management. Run Discmanagement and find the new hard drive, initialise it and format it.
That should solve your problem.
Nov 03, 2010 | NEC Computers & Internet
Hard drive
if its a brand new hard drive u need to initialise it by doing the following - start > right click on "my computer" and click "manage" go to disk management and look for the drive, click on the left square for the drive which should be black if not initialised and chose to activate it
Jun 08, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Scanwagon won't stop pulling back
try installing this patch ;)
hope it helps .
all the best
Sep 22, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP LaserJet 1320 Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
