Question about Dishwashers
Hi! I am getting an error 003 occur not long (maybe 10-15minutes) after i turn on our dishwasher. I am guessing its the "Midea" brand of dishwasher, as after googling the model number WQP12-9227A, there are some references to it being the Midea brand. Please help! Am sick of hand washing the dishes! If it helps, it has a blue digital display (Right hand side) of the control panel. Thanks heaps in advance! Garrett
5 Suggested Answers
SOURCE: Midea dishwasher WQP12-924OA wont go
hold power button down for 10secs while plugging in mains
Posted on May 07, 2008
biigg53566
  • 81 Answers
SOURCE: My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Posted on Nov 18, 2008
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
  • 109 Answers
SOURCE: Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Posted on Aug 14, 2009
I bought a FS40-8MW/FS40-SMB fan and it was missing the small pieces. No plastic nut or spinner - Can you send these items to me at B.Townsend, 101 Vandenberg Cir, Roseville, CA 95747 Thank you
Alas Barbara Townsend,
I have a very soft spot in my heart for Roseville...
Specifically ... There is NOTHING ... FIXYA
only has FREE ADVICE.
>> Please...
EDIT this question and REMOVE your
private & personal information...
Name & address... (etc.)
((it is an IDENTITY risk you don't want... I assure you)).
Notwithstanding ... it appears you have an OSCILLATING FAN
MIDEA (currently listed under "DISHWASHER") is still a viable
manufacturer...
1-866-646-4332...
NONE of my usual parts suppliers recognize EITHER
MODEL NUMBER you posted... HOWEVER
eBay has proven quite helpful FINDING OBSCURE
bits & parts when I've been restoring things
(again... no exact matches (look for "donor" parts)).
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xmidea+fs40.TRS0&_nkw=midea+fs40&_sacat=0
Would that we could...
FIXYA is still only an independent ADVICE organization...
Hope this helps!!
Owners manual
Midea FS40 8M Instruction Manual
midea.com/us/contact-us
Midea Contact Us Best Home Appliance Brand Make Yourself At Home
eBay
19results for midea fs40
Carnac the Magnificent
Jun 20, 2017 | Dishwashers
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
How do i fix code E9 on midea air conditioner
I have a problem with Midea Brand Aircondition .display shows E9 code error,what is a solution
Dec 22, 2012 | Midea Heating & Cooling
Unauthorized device has been detected
Error Message: Error 003 Unauthorized Device Has Been Detected
Situation:
System is displaying error message: Error 003 Unauthorized Device Has Been Detected
Information:
This error code indicates the region the system was manufactured for is not compatible with the Wii System Menu update. This incompatibility has made the system unplayable and it cannot be repaired. Nintendo is not able to provide support for these systems.
It has been modified so you will have to buy a new console sorry.
Oct 22, 2012 | Nintendo Wii Console
Hi, I have an E4 error message on my Midea WQP8-9325 dishwasher. In my instruction manual this is detailed as "overfilled" and the possible cause is "too much inlet water". I have had a...
Well there is water by the sensor or the sensor is bad. Do you run your garbage disposal and clear it out before you run your dishwasher ? I would say you have a clkogged or slow drain on your dishwasher I would check that and there lies your problem. could be you have some debris offf a pan in there slowing or trapping water down there enough to get your code. Clear it out and see if that rids you of your problem ,I'm sure it will and you will even find the sensor in the process to see what is going on.
Jun 23, 2011 | Dishwashers
Hi have an error 003 can i fix this?
I have found a solution at: http://www.wiihacks.com/blogs/mauifrog/316-error-003-fix.html. However it seems rather complex and involves modding. Apparently this problem only occurs on Korean Wiis that are out of the region and updated past the 4.2 system menu. Good luck with that one pal, I don't know where you got your Wii, and if it wasn't from Korea you have some questions to ask someone...
May 17, 2011 | Nintendo Wii Console
Hi all, I have an LG WD-1049C front loader 7.5kg machine. Its about 4 years old and I've never had a problem until now. I get a error code being "FE", which the manual says is "Water...
Are you sure it is not an "tE" error code. Sounds like a thermistor error. A $6 part. Kinda easy to replace but must turn washer on its back or side to get to. Answer back with a comment to this answer if you want more info or repair guidance.
Mar 30, 2017 | LG WM2688H Front Load Washer
I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Jan 16, 2011 | Xerox Office Equipment & Supplies
Problem of Midea dishwasher WQP12-9240A
yOU SHOULD BE ABLE TO USE THE SERIAL AND MODEL NUMBERS. The factory technician will ned those at the least.Look up the Midea on the internet and get the factory rep to explain the warranty or the dealer you purchased the unit. Good Luck
Jun 01, 2010 | Midea MPM-08CR-BB4 Portable Air...
Fails to start Midea dishwasher WQP12-9240AS
Thankyou Loopyloolisa! you just helped me fix my unresponsive midea dishwasher! Great help
Jan 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
