Question about Bosch Classixx WFO 2466 Front Load Washer
The key symbol keeps appearing on screen stopping us from using machine how do we get rid of it
    Brigadier General:
  • 6,277 Answers
(repeat!)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct. You may find, however, that it will supply only to service engineers but good luck anyway.
Good luck,
John C.
Posted on Apr 11, 2011
How do i get rid of the key symbol
Push the buttons which have a key symbol for 3 seconds and the washer can be used after unlocking the child lock. Download your WHIRLPOOL AQUASTEAM 9559 WP user guide or user manual
Mar 08, 2015 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
Cannot get rid of the lock symbol and it won't start even b4 the symbol appeared?
This sounds like a faulty door lock switch or a faulty main electronic logic board.When the door lock switch is faulty or opened it pauses the main board to allow the machine to stop working without switching off completely so that you don't lose the cycle when opening the door during a wash.But there should be a button to push to release the door lock when starting up the machine.if that doesen't work then there is a breakdown of communication from the door lock switch to the main logic board and visa versa if the board is faulty.If your machine is more than five years old then those two problems are the most common in those machines. Have a technician check it out.
Apr 15, 2013 | Washing Machines
Washing machine has stopped and a symbol of a key is flashing. Door will not open and no program will work
The key and flashing = child lock.
To get rid of this - turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Nov 27, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch clasixx machine there is a symbol like a key on timer and machine wont start how do i get rid of this
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Washing Machines
Bosch Classixx WFO 2466 Front Load Washer Logo
22 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
