Question about Bissell 16603 Powerlifter Vacuum
How do I remove the top cover to expose the pump motor for my Bissell PowerLifter Canister Cleaner 1660 series? The pump seems to "make noise" like its running, but it doesn't move any cleaner to the spray head.
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Bissell ProHeat Carpet Steam Cleaner stopped spraying.
Problem could be a stopped up heater unit which is located in the handle. The two clear hoses going up the inside of the left wheel go to the heater. There is also an in-line water switch located directly above the heater. The trigger for water release is in the top part of the handle. back to the heater... mine was corroded inside. Removed 5 screws holding heater cover. clean water trough and reassemble. If you need new washers go to Ace hardware. The smallest size metric rubber washers seem to work fine. take old rubber washers(red?) with you for comparison.
Posted on Mar 03, 2008
SOURCE: Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Posted on Jul 14, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
I need a new motor filter for my Bissell powerlifter
I need one too but can't find one anywhere either. I think I may try using some foam cut to fit.
Oct 09, 2012 | Bissell 16603 Powerlifter Vacuum
Manual for bissell powerlifter
the manual may not be available on the canadian site. but do try bissell.com and see what you can find under the customer service tab.
I plugged in your model number and nothing came up.
good luck.
Nov 15, 2010 | Bissell 16603 Powerlifter Vacuum
No instruction manual for bissel powerlifter carpet shampooer
go to this link:
http://www.bissell.com/customer-support/
there is a spot to put your model number in and you can download the owners manual. Good luck! Regards, Ross
Sep 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Manual says series 7901 and series 8910. Won't
In order to spray anything out of this machine, you need to have water in the bladder and water or solution in the smartmix bottle. If you don't have both, it won't work. Try this first, if it doesn't work you can access the tubing under the housing cover. You'll need a phillips screwdriver and pliers. Lay the machine handle down and take out the water bladder. There are two screws just in back of the bladder compartment; two in the middle of the compartment and two at the front of the floor noozle. You will also have to loosen and take off the round clear cover, red pinwheel and white strainer of the smart flow. (Mine is on the top left of the cover). Take the screws out and gently lift the cover up. This exposes all the tubing, the pump, etc.
I took off each hose separately and used an air canister to make sure the tubes weren't clogged. I just couldn't figure out how to get to the two ends that go into the inside of the wheel.
I hope this helps.
May 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to remove an old Rainbow E Series Cooling Filter
The motor filter is under the top cover.
Caution: Be sure your vacuum is unplugged from the electrical outlet before proceeding! There are 2 screws on each side of the top cover of the Rainbow ‘E’ series vacuum cleaners located behind the decals. To get to the screws; use a non-scratching tool such as a plastic putty knife and pry out a corner of the plastic window, carefully pull out the plastic window and decal and remove the 2 screws. Repeat this process for both windows and then just lift up the top cover to expose the inside.
Oct 25, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Changing Belt
you have to unscrew the bottom of cleaner, there are instructions on bissell.com under removing a belt. Go to user guide
Jul 26, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
How do you get to motor?
To get access you need to remove the plastic side cover panels. To remove these, I found the easiest way was to use a small flat screw driver, leverage it under the pastic in the centre at the 'cord end' and lift carefully. There are two lugs at the top and one at the bottom. The plastic panel will 'bow' a little, but with care, it will pop off. The gold looking vents underneath are just a 'facade'. By removing the side plastic panels they will expose three screws either side. Undo these and the top will half of the cleaner will lift off. Good luck!
Dec 09, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
89 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
