Question about Seagate (ST310005EXA101RK) 1 TB USB 20 Hard Drive
First of all...I'm a new userof Ubunto...I'm trying to install my seagate external network harddrive on a computer with obunto but I can't use the installation CD. How do I do?
  • 827 Answers
Hello Andreas,
Connect to the Internet. You will need access to the Internet to download the install files.
Open your Terminal in Ubuntu. This is the screen with the prompt where you can type commands.
Type "sudo apt-get install Gparted." Type in your root password and answer "Yes" to any prompts.
Type "sudo GParted." This will open GParted.Click the GParted menu and select "Devices." Select your external hard drive from the list. It is important that you choose your external hard drive and not the drive that has your system installed on it. One way to ensure this is to check the capacity on this drive; for example, if your internal disk is 80 GB and your external disk is 40 GB, choose the disk that is 40 GB.Click the "Devices" menu and click "Create Partition Table." Click "Advanced." From the New Partition Table menu, choose an option, depending on your system. For example, if you are dual booting Windows and Ubuntu, you may want to choose MS-DOS. If you are only running Ubuntu, choose GPT.Create a partition. Select a section of unused space and click "New."Set up your partition. For partition size, set the size of your partition--for most purposes, you can make the partition the entire capacity of the disk. Next, choose a partition type; primary is suitable for most purposes. Next, choose a file system. For sharing across a Windows system, use Fat32. For sharing with an Apple system, use HFS or HFS+. For use with an Ubuntu system only, use EXT2, EXT3 or EXT4.Click "Apply." The operations will run and your hard disk will be ready to use.
Posted on Apr 10, 2011
Using Seagate Goflex Hard-drive 750 GB, upgraded Windows 7 to Windows 10. get message Seagate harddrive not supported on Windows 10. Is there a solution to fix this? Russ
Will My Hard Drive Work With Windows 10? - PC Magazine
www.pcmag.com > ... > Windows 10
PC MagazineJul 29, 2015 - Some drive manufacturers have gone through the Windows 10certification process, ... Seagate products are NOT compatible with Windows 10.
Seagate GoFlex not compatible with Windows 10 - Microsoft Community
answers.microsoft.com/.../windows/.../windows_10-hardware/seagate...n...
Aug 4, 2015 - Since, the Seagate Dashboard is not compatible with Windows 10, let's try ... 10 with my Seagate FreeAgent Go Flex Home 1T external hard drive - model ... Windows 10 Backup Not recognizing Seagate Desk External Drive ...
Aug 18, 2015
Windows 10 Install- Now Seagate External USB 3TB HardDrive ...
Aug 13, 2015
Seagate 3TB external hard disk not working with Windows 8 ...
Jan 26, 2013
More results from answers.microsoft.com
Dec 16, 2015 | Seagate Computers & Internet
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
Externalseagate 250go not open how to solve
If you cannot open or see the harddrive when you connect it to your computer after it is powered on then that is the external harddrive itself. First, check if the power connection is connected and the usb cord connect correctly. Then see if any lights come on on the external hard drive. If lights does come on and still nothing showing or coming on to the computer, then your harddrive is history. Seagate makes one of the worstest hardrive. You can google this up about seagate promblem and there are thousand out there who have this same promblem. I know this because I have the same promblem you have.
Jan 17, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Need Manual or Instructions for Seagate Portable Hard Drive
Your External Drive should be plug and play enable since it is a USB Drive.
Connect the appropriate cables to the External Drive and from the External Drive to the Computer while the computer is fully booted.
The driver for the Drive is loaded else you will be promted that the system have found a new device, if that is the case, put the CD-ROM that came drive and follow the instruction to complete the driver installation.
Open my computer icon on your desktop and you see the external drive.
Feb 01, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,honglake@gmail.com
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
My seagate Free Agent external harddrive fell on ground yesterday. I unplugged it from the computer and try to use it again but it doesn't even show on the computer. The PC doesn't show the name of the...
Hard drives can make a little noise when you shake it gently, but to hear clicking sounds when it's running is not a good sign. I dropped a brand new 120 gig hdd for a customers lap top right outside the store. It made noise when I shook it "carefully" but nothing installed. NOTHING..... Tested it. It was dead. Since you say it's an external see if all inside is connected tightly.
Jul 15, 2008 | Computers & Internet
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Seagate (ST310005EXA101RK) 1 TB USB 20 Hard Drive Logo
136 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
