Question about HTC S710 Smartphone
When I'm using the phone suddenly the picture goes black (disappears), then restart the phone to make the image back to normal. please help!
  • 129 Answers
1.your phone battery is drained check it.
2.or goto xda forum and get rom os to update your phone which is only way to solve problem.
3.connect it to pc when active syn goes green run rom file which is downloaded from xda.
4.your htc will flash with new rom and problem will overcome.
Posted on Apr 10, 2011
Techwood natus m 1032
Check its back light inverter side circuit. Check whether there is ano loose solder terminals or loose wiring.
May 01, 2013 | Televison & Video
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
I have a Vizio 50"
Good day!!!
That problem is usually cause of bad inverter board or T-con board also there is the possibility that you have failing capacitors....
If your TV is totally black even back-light the problem is inverter board..please try to replace it to fix your TV.
If your have back-light but no image comes out...The problem could be on the T-con board..if that so please replace it...
This is for bad capacitors...
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter..
Look at the label capacitors...That is the sample image..
I hope this solution will be helpful...Thanks for using fixya...
Aug 17, 2011 | Vizio VX42L 42 in. LCD TV
Help! i can't turn on my camera!
If this is a new camera, take it back.
Sep 03, 2009 | Canon PowerShot A470 Digital Camera
Screen keeps going black, and sometimes computer restarts
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | IBM ThinkPad T42 Notebook
L took some pictures last night and then decided to put some into black and white. l pressed the format option and all of a sudden all the pictures disappeared. the camera is a hitachi hdc 86IE or is it...
yea i got the same camerA
i just tried that now you know foormatting it and it says *NO IMAGE*
i think you should next time just get your photo put on the computer anduse fotoflexer.com (trust me ive used this site before
Jan 24, 2009 | Hitachi i.mega HDC-401 Digital Camera
After startup, all icons and taskbar disappear...
start your machine in safe mode and if you have any antivirus installed in it and is updated then scan it , your laptop is infected with virus . so scan it
Apr 25, 2008 | HP Pavilion dv6000z Notebook
Sounds like Spyware or Adware causing your issues. Try scanning it using http://superantispyware.com/ or AGV Free.
Joe
Dec 17, 2007 | Joy Satellite M55 S3314 Laptop PC
Icons And Themes Disappears!
u wil hav to flash ur mobile from care center  ur entire operating system wil be reinstalled & data wil be lost .
Oct 19, 2007 | LG Prada KE850 Cellular Phone
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
HTC S710 Smartphone Logo
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
