Question about Elna Sewing Machines
My elna has cams to upgrade the number of stitches it can do but I am unable to get them to work. I believe I have installed them correctly but cannot activate them.
  • Elna Master
  • 1,125 Answers
Throughout the Swiss Elna range there were several of their top of line models that have the black cams for additional stitches and they all have an "Elnagraph" device in the top of the machine case where you insert the cams.
There are single cams where the needle just moves ffrom side to side while the fabric moves forward. And double cams where the needle moves from side to side while the feed dogs move the fabric forward and backwards to get a combination stitch. The trick is to get the Elnagraph to engage so the arm in it can "read" off the disc.
There are a couple of other knobs that you need to adjust to get the cam stitch though.
Star Series: (white machine with blue top) you need to put the stitch selector inside the elnagraph flap to "A" on the Star series and then stitch width to 4 and stitch length to the red A zone.
Air Electronic SU or Carina: you have 3 knobs from left to right - stitch selector (put it on 7) , stitch width (put it on 4, orange area) and stitch length (turn it around to the orange zone for the automatic stitches).
And on the early Supermatic the adjustments are a little different again.
And ALWAYS turn the stitch width and length dials back to zero, before you change the stitch selector, or pop out a cam.
I hope this helps you get your Elna stitching from the cam, there is a great Yahoo group called Elna Heirlooms too where there are lots of knowledgeable Elna owners and some files listing all the cam stitches.
Posted on Apr 10, 2011
I need a manual for an Elna Air Electronic SU that has "cams". I can not find a model number. What is or where is the model number so that I can order a manual.
Somewhere on your machine, perhaps underneath, inside, or on the back, there should be a plate or engraving with the serial number and the model number of your machine.
http://whitesewingcenter.com/elnaidentify.php
Then search the internet inputting:
Manufacturer + Model + the word "Manual"
Sep 26, 2015 | Elna Sewing Machines
How to remove a can from a elna Carina electronic 65
you need to set the stitch width dial to zero, the stitch length dial to zero so that the cam following arm is disengaged and moved back off the cam. Now look at the cam, it is sitting on a silver shiny spindle, press down onto this with your fingers and this will unlock the little finger which locks onto the cam, releasing the cam upwards. Press firmly and it should release.
Jul 03, 2015 | Elna Sewing Machines
Why do the automatic stitches and cams on an elna su not work?
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jun 08, 2014 | Elna Sewing Machines
Zigzag feature is not working
Jan 09, 2014 | Elna Sewing Machines
Does anyone know of a cam to use in an Elna Carina that makes a stitch very similar to french entredeux? What is the cam number?
I am certain that we demonstrated this stitch with voile or hankerchief linen and using a wing needle and fine silk thread or rayon machine embroidery thread with the turkish hemstitch cam, cam number 140.
For the non heirloom sewers out there entredeaux looks like this.
Here is disc 140in the Elna discs sampler flyer
I am a member of the yahoo newsgroup called "Elna Heirlooms" and the following image was contributed by a member. I believe that members also list any Elna items they may wish to sell.
Or you could contact White sewing centre to order this cam if you don't already have it.
www.whitesewingcenter.com
If you find these images are just too small, feel free to email me on cwrogers@tpg.com.au and I'll send you the jpgs.
Jul 13, 2011 | Elna 2005 Mechanical Sewing Machine
Machine Elna Supermatic 722010 When I sew with a single cam all works properly the problem comes with any twin cam, the upper cam follower has a spring holding it away from the cam, how do I get the upper...
tally_girl_2.jpg I don't suppose it would be so simple as setting the wheel inside the elnagraph to "A" to engage the automatic stitches? I've done it myself once or twice LOL.
Mar 29, 2010 | Elna Heirloom Edition 6005
Have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Mar 11, 2009 | Elna 1010
Elna 2002 -
The question was regarding the Elna 2002 not 2007 and it wasn't a problem. I just do not understand how the pattern selection works. Thank you.
Dec 04, 2008 | Elna 2007 Mechanical Sewing Machine
Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Jul 05, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
459 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
