I used to have a jvc player dr-mv1 and didnt finalise the disc's and then it died and now i cant play my disc's is there i programe or another player that will?
  • kael55 Apr 13, 2011
    down loaded convert x but it didnt work, my pc or any dvd player wont read the dvd because it wasnt finalised, i need a programe that will be able to read it and finalise it.
  • 635 Answers
You see most of the DVD recorders use a format called MPEG for sound and video. Unless you have an old Philips DVD player most of the modern DVD player does not support this format. The DVD format is called MPEG 2 and sound is in Dolby Digital / PCM / or DTS format.
There is one thing you can do, you can convert all your precious recordings into DVD format on your PC by downloading a free software called ConvertX. This will make it playable on all DVD players.
There is no point in trying to fix your old machine because it might cost you more than half the cost of a new recorder itself to repair.
Here under is the software link.
http://www.vso-software.fr/products/convert_x_to_dvd/download-convertxtodvd.php
Posted on Apr 12, 2011
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Jvc dvd/vcr player records from vcr to dvd but only plays back the dvd on the jvc DR-MV79 won't play on any other dvd players
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Dec 25, 2010 | JVC Televison & Video
Does putting objects on DVD player cause problems? Have two that no longer play after putting light TV on them.
Sir. i have victor jvc dr-mv1 and i need English Languige on this DVD please solve my problem.
Jan 30, 2010 | Televison & Video
Firmware crashed, unable to get repair in UK
I also have a faulty unit with discs that hadn't yet been finalised. You can access the discs via your PC. I used a program called IsoBuster by Smart Projects. There is a free demo which you can download. Just google it.
As for the faulty power supply, just scrap the unit and DON'T buy JVC again. Eventually, they will have to listen to the economies of scale.........
Sep 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
I have a JVC DR-MV5S. When I dub a VHS to DVD,
The disk must be finalized. Instructions are on page 79 of the instruction booklet for the MV5S. I can't get the manual to download from the MVC site, but maybe it will work later. Hopefully you have the manual.
Jul 13, 2009 | JVC DR-MV5S DVD Recorder/VCR
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Apr 15, 2009 | Televison & Video
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
Can't finalise dvd containing AVI movies copied from USB
I would use your PC to finalize discs containing AVI files. There just isn't a way to do it from the Philips. I personally use Dr. Divx, but there are many programs out there that will do this.
Aug 09, 2008 | Philips DVDR3575H/37
How do you get the DR-MV1 into service mode?
service menu? do u mean the menu? if u have it's remote...it should be in "menu".
Mar 29, 2008 | JVC DR-MV1S DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
