Question about Garden
How do I adjust or remove the blades ? - Garden
There should be on the chain side a nut holdin the case on . just loosen the nut a bit then on the front of the chainsaw there should be a screw to ujust the chain try do it up or loosen it and feel the chain to see if it gets looser or tighter
Posted on Apr 10, 2011
Sharpening blades for qualcast 35s
With a cylinder mower the sharpness of the blade is only part of the concern. The fixed blade is like one of the blades of a pair of shears and each "blade" of the revolving cylinder acts as the other.
As long as only grass is being cut (no stones) the blades will last a long time with only occasional adjustment to the fixed blade as per instruction manual.
After much use or in case of damage the fixed blade will need replacing or sharpening. If it is badly worn it will need removing and sharpening by a specialist with the correct equipment but otherwise the light application of a file, stone or a patent sharpener and then readjust the blade per manual.
When eventually the cylinder becomes worn or sustains damage it must be removed and machine trued and sharpened using a lathe or similar.
An accurately sharpened cylinder and a true and sharp fixed blade correctly adjusted will consistently cut paper across the complete width of the blade when turned by hand. A competently sharped and adjusted cylinder mower will cut the thinnest tissue like the finest scissors without binding.
Aug 18, 2016 | Health & Beauty
How do I change the blades on a vermeer 1600A chipper
Place the chute over the rotor. Remove all the clamp bolts for one blade. This will allow you to remove the old blade and clamp bar. Clean clamp bar and blade slot. Install new blade with clamp bar. You will need a knife gauge for this. Use the knife gauge at each end of the blade. Torque clamp bolts to 280 ft. lbs. After blades are installed it is necessary to adjust the bed knife by loosening the three bed knife bolts. Use the set screws to adjust the bed knife to 1/16 in. above the lower feed plate. Torque the bed knife bolts to 250 ft. lbs. Then use the other two bolts to adjust the lower feed plate to .013 to .016 between the bed knife and the rotor blades. Put the chute back into place and you are good to go.
Dec 08, 2011 | Garden
I do not have a manual.... I can't adjust the tension. It looks like I have too much chain, the screw is as tight as I can get it. Help!! I have a Cordless Chain Saw, model CCS818 TYPE 1.
the bar should also raise and lower when you apply tension onto the blade - one way or the other it shoudl allow you to tighten the blade.,.. If it is still loose after that, you may be more safe to grab a new blade if this is from wear or use.
Also another fyi: If you get these blades hot and too tight, when they cool, they can warp your bar... I always loosen the chain on mine (per owners manual) immediately after use so it will not do any damage when it cools down..
Did you try to find an owners manual at black and decker dot com?
Best regards
Ck
Mar 08, 2011 | Black & Decker CCS818 Chain Saw
How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Jun 07, 2010 | Skil Saws
How do I adjust the blades or sharpen blades on a Andis T-Outliner trimmer? I have some older blades that work farely better then my newer blades that are dull if you ask me. Is there some way to manuver...
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Feb 05, 2010 | Andis 04710 Beard Trimmer
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
How do i adjust my new outliner 2 blades?
remove the 2 front screws that hold the blade, remove the blade, this has two small screws losen the screws DONOT NOT remove these screws now mve the smaller blade up or down to the hieght you want. when u finish with your adjustment tighten the small screws replace the blade and center the blade in middle.
Sep 27, 2009 | Andis Outliner II Hair Trimmer
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
How do i take off and replace the blade on my berkel bandsaw
There should be a blade tensioning adjustment on the back of the upper wheel. You need to loosen this until the blade is loose, then open both front covers and possibly remove the guard, then install new blade and retension.
Then adjust the tracking and guides as follows:
Before tuning it up, loosen the guides and wheels away and square the table to the tensioned blade. Then follow these steps in order:
  1. First, adjust the upper wheel so the blade is tracking at the center or just to the front of center of the wheel tire. (You can see this with the cover removed, and adjust it with the nut/wing nut in the back).
  2. Now, make sure the blade guides are adjusted so they don't deflect the blade to either side (when looked at from the front), so they contact the blade just behind the gullet of the teeth, but not against the hooked teeth themselves, and are just tight enough to allow the blade to run freely (including the weld). (If your guides are worn and out of flat, you may wish to dress them on a sander before adjusting them against the blade.) Adjust the guides both above and below the table. At this point, ensure that the guide bar moves up and down easily and locks into position without torqueing the guides against the blade.
  3. Finally, adjust the bearings behind the blade, so they just kiss it, and turn freely when you revolve the bandsaw wheel. They will support the back of the blade when pressure is applied against it during a cut, and help immensely to keep the blade tracking straight.
At this point, check the cut by trying to follow a straght line penciled on a board. Some blades will naturally tend to veer slightly on a diagonal, depending on how they are sharpened, and you may have to adjust your fence to compensate for this "drift".
But if you follow the steps outlined above, and have a good sharp blade to begin with, you should be able to split a line.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Mar 23, 2009 | Saws
Andis masters are chewing my guards
Stop using speedo guards and get yourself an oster 76 and all the blades.
Aug 16, 2007 | Andis 01690 Hair Trimmer
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
