Question about Samsung Washing Machines
Dose not spin - Samsung Washing Machines
    Brigadier General:
  • 6,277 Answers
(try this first!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 11, 2011
WHY SPIN DOES NOT WORK?
You have something stuck between the the outer and inter tubs
Jul 13, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
W863
dose it spin verry slow while it heats up , can u put it on just a spin if that dont work it could be motor
Apr 15, 2014 | Washing Machines
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
This washer wont spin but it dose drian
Most likely your motor coupling is busted.
part number is 285753A
May 17, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Upper arm dose not spin
have you checked to see if the arm spins freely if you push it
Apr 13, 2009 | Beko 24 in. D3421F Free-standing...
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
Blower/heater speed control switch just spins=no heat or anything
I found your blower motor switch here for $24.33 plus Shipping and handling. Thank you, and don't for get to vote. http://www.audiporschevwparts.com/
Jan 29, 2009 | 1989 Audi 80
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
29 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
