Question about Compaq Computers & Internet
I hae a compaq 9010 laptop and the on off button has come unclipped from under the keyboard. anyone kow how to lift the keyboard up.
  • Compaq Master
  • 5,660 Answers
Above the Keyboard, and directly under the LCD screen is the Keyboard Cover. This cover contains the various LED lights, and Power On button.
1) ALL power to the laptop is removed. The AC adapter (Charger) and Battery.
2) Two Philips head screws are removed from the back of the laptop, which fasten the hinge cover portion of the Keyboard Cover to the laptop.
3) A thin flat-bladed screwdriver is used to gently pop the Keyboard Cover up.
On the Right and Left sides of the Keyboard Cover, and also the middle, (Side towards the Keyboard), a small flat-tipped screwdriver is used to gently pry the Keyboard Cover up.
Use care so as to not damage the plastics, nor the wireless antenna.
This is the download page for the Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=321957&prodSeriesId=321850#2
Under the Service Information heading click on - Service Manual
This is a PDF file. Allow time for the first page to come up, and additional time may be needed for the file to fully download.
Should you have any questions please post in a Comment.
Regards,
joecoolvettte
Posted on Apr 10, 2011
KEYBOARD REPLACEMENT SONY VAIO VGN T350P
every laptop is different some have screws underneath some have a part of the casing above the keyboard that can be removed by sliding it to one side revealing the screws underneath this could also house the power buttons and some unfortunately require the complete laptop motherboard etc removing first and i know with my sony this is what i had to do, so firstly check for a strip above the keyboard and try sliding it to one side, if there is a strip then youre in luck as it will normally reveal 3 screws holding down the keyboard which will allow the keyboard to lift and unclip and then you just need to unclip the ribbon cable from the motherboard, if theres no strip then you could try turning the laptop over and removing any screws that are directly under the keyboard and see if this frees it and also removing any memory and hard drive that may be hiding any screws, if this does not solve your problem then you are heading for a complete stripdown of the laptop base which unless you feel competent in doing so is best left to the experts, hope this helps
Dec 29, 2013 | Sony VAIO VGN-AR130G PC Notebook
T1005M KEYBOARD CLEANING
You can lift the key up and it will unclip from the key hinges. To replace the key, place the key on the hinges, align it with the other keys, press down until the key clicks onto the hinges.
Aug 27, 2012 | Gigabyte T1005M-CF1 N550 10.1-Inch...
Where is the onboard memory
Download your manual from compaq support page and it will show you, its usually under your laptop, there are covers for memory and hard drive, 1 or 2 screws later and your in.
Some laptops memory is under the keyboard, usually you unclip a strip at the top of the keyboard and lift keyboard out
Jul 17, 2010 | Compaq Armada 1592DMT Notebook
I have a Compaq CQ50 laptop, there seems to be a short or bad connection somewhere just under the power button or keyboard. I say this because the power button is not working, I press the botton and...
I was working in a computer with the same problem, when you remove the keyboard and the keyboard cover at the right side of the power button you can see an small plastic cap with two wires, is the num lock led, when the wires are under the top cover and the screws of the keyboard or the cover are too tight the wire is damage and make contac with the earth shuting down the power supply, check the wires, repair if broken and take care that its not under the top cover when you assembly.
Sep 24, 2009 | HP Compaq Presario CQ50-110US Laptop
Thanks for your support
Remove the keyboard screws first, the screws that secure the keyboard have keyboard symbols next to the screws.
Some Compaq/HP have slide catches along the top edge of the keyboard between the number keys and the Function keys. Usually the slide catches are located between the ESC & F1 key, F4 & F5 key, F8 & F9 keys, F12 & delete keys. Slide these catches towards the front edge of the keyboard (ie. towards the space bar) you should be able to lift the keyboard clear. Don't forget to unclip the ribbon cables on the keyboard.
Jan 28, 2009 | HP Pavilion dv1000 Notebook
Is it difficult to replace the keypad on the compaq nx 9010
Keyboards are easy, and remove in two different ways on just about all laptops. 1- There are screws on the bottom that hold it. 2- The screws are located under the power button strip at the top of the keyboard. The strip snaps into place, so lift it up on one end and work it up and off. You can find a replacement keyboard at Ebay for a decent price. Here's a couple of links that you may find a breakdown diagram for your machine.
http://repair4laptop.org/notebook.html
http://www.eserviceinfo.com/service_manual/datasheets_d_600.html
Jul 02, 2008 | HP Compaq Business Notebook NX9010
I'm upgrading Ram Compaq R3200 laptop
Found my solution. Was under keyboard. Required opening laptop as far as possible, removing 3 screws from the back that hold the piece of plastic just above the keyboard. With flathead screwdriver lift the right corner of the plastic piece then, with the same screwdriver lift the top center of the plastic piece to remove the piece entirely. Unscrew the 4 screws that hold the keyboard (across the top) and lay they keyboard forward (toward you). THERE is the Ram.
May 22, 2008 | HP Pavilion ZV5000 ZX5000 Compaq R3000t...
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Nx 9010
Simply plug the ac adapter into the wall, the laptop will charge the battery itself.
Keep in mind this... in general, a laptop runs at full speed when it is plugged into the wall. When most laptops are running on battery, things are running more at 50% capacity to save on power, this giving you more battery life. A dimmer lcd and slowing the processor down when not needed are common traits.
You can use the FN key (function key) and the corresponding dim control on the keyboard to adjust the brightnedd of the backlight. It should be marked on your keyboard in a different color, like blue or maybe green (not familiar with that models keyboard).
Oct 21, 2007 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
