I ve purchased a Foxin TV tuner Box Usb and connected it to my desktop....But after installation,it could not find my Tata sky connection,connected to it.and i m a novice so i dont know the procedure to search for channels in the settings, also I would like to know how to connect it to my pc and my Tata sky set top box
  • 24 Answers
SOURCE: Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Posted on Aug 20, 2008
SOURCE: Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Posted on Aug 27, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: how to connect tv set to digial tv tuner converter box
There are two ways to connect a converter box.
The simplest is to use the RF antenna cable supplied with the converter. Connect it from the box (the round threaded connector) to the TV's antenna/cable input connector and put the TV on channel 3 or 4 (whichever the converter box is set to). If your set has screw terminals for the antenna connection, you'll need an adapter to switch from the round cable connection to the screws. This may also have been supplied, but you'll probably need to pick one up at Radio Shack or another retailer.
The other way, if your TV has the inputs, is to use the audio/video output jacks on the converter. Again, the cable is usually supplied with the box. This direct connection gives better picture and sound quality than the RF method. The jacks are color coded: red and white for the audio right and left channels, yellow for video. Just connect them to the matching jacks on the TV and select the video input to watch the box. (If your TV is mono and has only a single white audio input jack, you'll need a Y-adapter to join the two audio signals from the box into one. This is also available at Radio Shack. If you don't do this, you'll only get one channel of the sound when watching a stereo channel.)
Please take a moment to rate this solution if you found it satisfactory. Thanks for asking!
Posted on Feb 11, 2009
  • 357 Answers
SOURCE: sky box saying no sattelite signals
Check the coax connector and the cable, try anoter cable if you have one available.
Good Luck.
Posted on Feb 22, 2009
Lanadmin_cam
SOURCE: How to view TV in a Desktop PC via a USB TV Tuner?
Depending on which kind of tv tuner you are looking (analog basic cable) or HD tuner, the higher end tv tuners will usually handle both basic cable or connecting via satellite or some sort of set top box.
I would look for the ATI TV wonder HD, your going to want a tv tuner that can do hardware encoding on the actual tuner itself, older tuners will rely on your pc to process a lot of the data.
Posted on Mar 18, 2009
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
Mar 13, 2015 | Televison & Video
Tv is 4 years old yesterday it lost its built in freeview channels. when trying to get the menu up it appears for a second then goes off. Tv still receives sky and picture is good
Hello pip_o
It's possibly a defective digital tuner, but the vanishing menu suggests a more serious (and expensive) fault with the main/AV board, assuming it's an LCD TV. It's impossible to be certain which one without doing some testing, but due to the inherent dangers with high-voltage electronics, I don't advise on self-repair for TVs.
If you're looking for an inexpensive solution and the TV is no longer covered by any warranty, I'd suggest buying an external Freeview box to connect to your TV. This would also enable you to upgrade to Freeview HD. Being 4 years old, your TV will not have been fitted with a DVB-T2 (Freeview HD) tuner.
If you want to try this solution, I can recommend the following box, which is great value at just £25.
http://www.ebay.co.uk/itm/270828771661
They are described as "reconditioned", but I've bought and installed 2 of these for my own customers recently and both have been brand-new. The majority of these are unused returns which Tesco are consequently not allowed to sell described as "new". For a lesser known brand, I've been quite impressed with some of the recent Technika products and they are easy to install and come supplied with all the necessary cables, etc. Additionally, if it doesn't work for any reason, you will be able to return it under UK Distance Selling regulations.
Before purchasing this (or any other) Freeview HD box, please check your TV has a spare HDMI input socket as SCART cannot carry an HD signal. If you don't have a spare HDMI socket, I'd also check your TV has a spare SCART input socket or you will need to disconnect your Sky box every time you want to use the Freeview box - which brings me to my final point . . .
. . . Off the top of my head, I can't think of any Freeviews channels which aren't available on Sky, so as long as you can still use your TV for Sky, do you really need to spend any money on it?
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Oct 09, 2011 | Televison & Video
How Tata sky HD superior than Tata sky?
Tata HD has clearer picture as it has high definition technology while Tata sky just has standard definition .
Regards
Mar 12, 2011 | Televison & Video
Currently i have a sky hd box connected to my tv by a hdmi cable i want to connect my ipod into the sky box so i can play music videos ipod and sky box are close together and i don't want to connect ipod...
This isn't possible, the USB on the front of the Sky HD box is not active. I don't have any information on whether it will be in the future.
Your only option is to connect the iPod via TV or if you have a surround sound amp
May 21, 2010 | LG LH-D6230 System
I want odyssey 501tv tuner internal driver software
i suggest u try the external TV tuner box...as those do not require any driver...not any installation of software...also it does not require ur computer to work...just ur monitor to be ON...
just connect ur monitor and computer thur the external TV tuner box and connect the TV cable to the tuner box...
Dec 23, 2009 | Computers & Internet
Mar 18, 2009 | Compaq Computers & Internet
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
PCTV 50i
Your PCTV card has got S-Video input. Just connect the S-video output of the Tata sky box if available or use a RCA to S-video adapter to input the video to the tuner card. Now for audio u can connect it to line in of PC. To watch or Record, just select the input as S-Video in the channel selection in PCTV application
Naveen
naveen.karuthedath@gmail.com
Dec 28, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
