Question about AOpen (MX4SGI4DN2PRE) Motherboard
Computer in in start up mode and a ladys voice keeps saying we have a problem. instuctions say hit del to enter but it does not work
  • AOpen Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Posted on Apr 10, 2011
The computer is not booting and I'm not sure what the problem is. It's done this before and eventually booted normally. I went into the BIOS to try to restore setting but could not find it. Help me pl
Press F5 during start up to enter safe mode and see if it boots then. CMOS values may have changed if CMOS battery is dead and values reset which means the computer no longer knows your drive type.
Try saef mode start up first then hit either DEL key or F1 to enter CMOS Bios at start up to see if Hard Drive make and size are posted.
- It's a start!
Dec 15, 2012 | Computers & Internet
Problem with my asus password
restart your computer and keep hitting "F8" over and over and over until a black screen comes up with a list of options of how to start windows. pick the one that says "safe mode with networking" go to control panel, then user accounts, then delete the password, then restart your computer and see if everything goes back to normal. If so, then go back to user accounts and make a new password and then restart, and see if everything works ok...my guess is that it will. Sometimes it's just weird that way...let me know what happens
Jun 09, 2012 | ASUS K53e B1 Notebook
I can't enter cmos althouh i press del or f2 when i press del ,next screen appear blank with cursor. will this problem solve by upgrading bios?
Restart your computer do you see prees f2 or something else
or
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Jul 03, 2011 | MSI PM8M-V Motherboard
How do I fix or repair my HP mini 1000 Netbook with it being stuck in a boot loop? I am getting the "unmountable_boot_volume screen. My netbook does not have a CD ROM drive.
Check your bios to ensure its first boot option is set to the hard drive instead of CD drive or USB drive. If you have a thumb drive plugged in, unplug the USB and try again. On your boot screen there should be an option to hit a key to enter bios (Usually Esc, F2 or Del). Hit whichever key it requests and enter Bios. Once in Bios look for Boot Order and check to see where the Hard Drive is in the order. If it is not set to #1 then do as it says to set it to the first option. Once done hit F10 to save and Exit and return to boot.
Feb 04, 2011 | HP Mini 1000 Netbook
I did a system restore and it says that it was unsussessful and shuts down. I restart the computer and it says unsussessful and shuts down. How do I fix my computer?
There should have been a recovery CD that came with your E-Machine. Put that in and restart the computer. If you've already done that, then you might not have the CD drive set as a first boot priority. restart the computer and look to see what button it says to push to enter "Setup." If you can't find it, try the "Del" button. restart and right away start hitting "Del" over and over until it says it's entering setup or it actually enters setup. find where it says boot. you'll have to use the arrows, the mouse won't work. go to boot and look for "Priority" hit enter and you'll see some options for 1st, 2nd, 3rd boot device. make the first one the CDROM and the second the HDD or hard drive. Then hit F10 to save and exit it'll restart and should restore then.
Dec 08, 2010 | E-Machines (T2958) PC Desktop
When starting my medion laptop it fails to enter bios. What can I do? Have tried everything hitting the F-buttons and del
Try F1.
Try F2.
Try F10.
Try F11.
Try F12.
Try ENTER.
Or, with the computer turned-off, press and hold the SPACE BAR.
Turn the computer, and keep holding until you see the "keyboard error, press <blah> to enter setup". Press the <blah> key.
Jun 29, 2010 | Computers & Internet
Forgotten password
Go to Safe mode using the F8 key.
( Shut down the computer --> Now turn on the system and keep tapping the F8 key on the system.--> you will receive the windows Advance option--> choose the Safe mode option and hit enter--> choose the your operating system and hit enter..)
In safe mode if the computer prompts to enter the Administrator account --> Do not put any thing and hit enter --> that means use Blank Password and hit enter. If it works perfect follow the further steps. If it does not choose another account if exist.
In safe mode :-
steps 1:-
click on start--> run-->control userspasswords2 hit enter. Now the window which opens up--> uncheck the option which says :- Users Must Enter A User Name And Password To Use This Computer.
after unchecking it hit apply button at the botton and hit ok.
Now when you restart the computer will not ask you the Password and will take you directly to the Account.
once you are in you can remove the Password through the user accounts in control panel.
Try this and let me know if it works...!
May 20, 2010 | E-Machines eMachines Desktop PC
How to remove sowar virus on my pc
1. Go to Start, Run and type: cmd press Ok.
2. At the command prompt, type in your primary drive location, usually C:
3. You may need to change the directory. If so type: cd \ hit Enter.
4. Type: attrib -s -h -r -a autorun.inf hit Enter.
5. Type: dir and hit Enter. This will allow you to see and confirm the Autorun files.
6. Type: del autorun.inf hit Enter. Repeat the above commands for each drive on your computer including your flash/usb drive.
7. Now search for and remove sowar.vbs, SysRes.vbs, Cool USEP Scandal.vbs
  • At the command prompt, type in your primay drive location, usually C: hit Enter.
  • Type: attrib sowar.vbs.* -s -h -r -a hit Enter.
  • Type: dir /s sowar.vbs Hit Enter.
8. If the file is present, type: del sowar.vbs hit Enter.
  • Repeat the above commands for each drive on your computer including your flash/usb drive.
  • Then repeat these instructions to search for and delete SysRes.vbs, Cool USEP Scandal.vbs on each drive if present.
9. Exit the command prompt and reboot normally.
10. Disable autorun.
Dec 21, 2009 | Microsoft Windows Server Standard 2003 for...
I cant log in the screen just goes blank and all i can see is the mouse icon what can i do so i can log in my computer
Wyhen you power up the computer press F8 key then enter in safe mode.
Then go to start menu ->run type in run "chkdsk /r"
then press "y"
then restart computer then it fix error on harddisk.Also scan your computer with antivirus in safe mode.
Remove all temp files from computer.
Let me know if you need further assistance.
Thanks.
Nov 04, 2009 | Compaq Presario CQ60-220US PC Laptop
My computer wont work
There are many possible causes for this kind of problem. With Safe Mode not booting, though, the possible fixes become few. Your best bet is to put your Windows CD/DVD in the drive and reboot the system by turning it off and back on or hitting the reset button - hitting enter or CTL-ALT-DEL won't give you the kind of reboot you need.
As the system is rebooting, keep watch on the screen near the bottom - you *may* need to hit a key to get the computer to boot from the CD/DVD. Once it's started to boot from the CD/DVD, follow the prompts to re-install Windows.
If you get an option to format the drive, don't do it! Just choose to keep the file system unchanged.
Good Luck!
Apr 17, 2009 | Acer Aspire™ T180 PC Desktop
AOpen (MX4SGI4DN2PRE) Motherboard Logo
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
