While watching the picture and sound go off while the green light stays on. I turn my set off and back on and it plays for awhile and then does the same thing. I have also tries pushing the reset button.
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 10, 2011
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Dec 27, 2014 | Magnavox Televison & Video
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
I have a Vizio model P50HDTV20A. The problem is this. One day it would not turn on. I got the clicks then a green light. No picture no sound. So i let it sit with the green light on for awhile. Turned it...
Look for numerous bad capacitors on power supply or replace board. Also look for burn spot on square buffer ic's to left of cabinet with back off. Replace bd's as necessary.
Nov 09, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Dec 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a 2005 Mitsubishi HD1080 big screen that today, when I turned it on, the power light comes on, flashes but the overall screen never come on. Turned & unplugged the power for awhile to see if...
Hello:
There is a problem within the digital board assembly. This is the metal can like unit to the left side of the unit when looking inside it with the back off. The power management is inside this unit. There are 7 1000uf 16 volt capacitors on this small power supply that needs to be replaced. The pwr board is the first you see after opening the Digital unit. Replaced the capacitors with 680uf 16v capacitors instead of 1000uf. After replacing the capacitors looking thru the holes in the digital assembly there will be a green flashing LED, Watch this light for a moment, should stop flashing and stay steadily green if all is normal. Also the power light will still flash for at least 60seconds then go off. Turn on power and happy viewing...Cost to repair this should range around $200-250.00 dollars.
Thk Please leave message...
Oct 07, 2009 | Televison & Video
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
Apr 07, 2009 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
