Question about Cell Phones
I got my 6300 corrupted because i try to update the software and when the update goes on it failed and my phone turn off what will i do pls help me thanks in advance.
  • 133 Answers
Is this the OVER-THE-AIR process of updating your phone?
try to update and format it using PC and follow this steps.
Try to re-program your cellphon using the nokia software updater, just go to www.nokia.com
select your region, now, go to SUPPORTS tab, after that, click on SOFTWARE AND SERVICES, then, DEVICE SOFTWARE UPDATE, select the MODEL of your HANDSET, even you have the same firmware version, you can still update or correct some errors in your handset. AFTER choosing the model of your PHONE, go to the bottom part of the page, CLICK on DOWNLOAD UNDER SOFTWARE UPDATER, make sure to download the software compatible with the operating system of your PC and the language ofcourse.
Now, AFTER downloding the file, just SAVE & RUN it in your PC, make sure to have stable internet connection and the battery of your handset is fully charged. follow all the instructions on how to update or reset your handset. By the way, for the instructions, you just need to plug your phone into the computer and run the software, you just have to click some buttons for confirming..
THAT's IT!!
Please make sure to Click on 4 Thumbs UP!! Thanks!
Posted on Apr 10, 2011
My 6300 was working perfectly and i just finish back up and i want to update software. so i just unplug the usb cable and after that my mob does not open even i press the on button many time as usual way...
Its an software problem you have to flash your mobile obviously you cannot able to take informations stored on your phone. Try switch on your mobile by power on + call+3 by pressing 3+call button switch on the phone
Mar 14, 2011 | Nokia 6300 Cellular Phone
Tip
"Unable to Open Theme Corrupted" in Nokia 6300
Hello Friends,
Here am trying to give a Solution for the Problem "Unable to Open Theme Corrupted" in Nokia 6300.I had tried many attempt to Solve this Problem.Finally found out a Simple and Easy Solution for this Error -instead of wasting money by giving in any Shops for Flashing the Phone(Software Update).If this problem occured in 6300,then there cannot be Possible to Apply any theme or even Open a Nokia Default Theme.The Error might be Displaying on Start up of your Device(Nokia 6300) and when trying to Aplly a Theme.
Requirements:-
A Computer having USB connectivity
Nokia Dke 2 Cable
Nokia 6300 Faulty Phone
You have to follow steps mentioned below to Eradicate/Solve this Problem.
  • Download Oxyfile (To Download Click here)
  • Install it on your Computer
  • Connect your Nokia 6300 with Specified Cable
  • Open Oxyfile Software Click on 'FILE BROWSER'
  • Click on C: drive(Mobile System)
  • Click on Plus icon of Gallery to Expand
  • Click on 'Themeactive'
  • Delete the file 'Theme.ini' and Other files in that Folder(Ensure Delete of File Theme.ini)
  • Unplug Your Mobile from Cable
  • Switch it OFF for 10 Seconds and Switch ON again
You are Done and Ready to Use..Your Problem Solved Now.Now you can Apply any theme on your Phone....I like to know your FEEDBACK....
>After Done this-it is better to Make an Update only if you want to get Benefit of Full Flash[Instead of Doing from a Service center]..
Download Updating Software from Here OR go to this Link
  1. Download and install Nokia Software Updater (this need only be done once).
  2. Connect your phone to your PC with a suitable USB cable and open Nokia Software Updater.
  3. Follow the on-screen prompts until your update is complete!
NOTE:Battery Should be FULLY charged When Starting an Update Process.Do not TRY to Remove Cable When Updating is in progress(Phone may be Permenently damaged if Unplugged)....Now your Phone look Newer than ever.....
Thanks for Reading this text ...If you like this Post-Don't Forget to VOTE ME....Keep Using FixYa....
To Solve "only 70 sets allowed setting discarded" in Nokia 6300 Click here
on May 30, 2010 | Cell Phones
In my phone the theme's are not appling (unable to open corrupted) in nokia 6300
hi
don't try to apply themes with larger size . because some nokia phone will support those themes but will be slow in action. restart your phone and tre to apply the themes. if still having same problem then format your phone. this will fix your phone..
thank you
Dec 20, 2010 | Nokia 6300 Cellular Phone
Calculator lost in nokia 6300
hi... jus connet ur mobile to pc wit nokia pc suite an up date th software r install th applications... so that ur prob might get solved... kindly rate me... thank you..
Jun 30, 2009 | Nokia 6300 Cell Phone
Nokia 6300 hangs
Select in settings menu option "restore factory settings"
Nov 25, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 programs download
try to update the software used in it by contacting the nokia care
Nov 17, 2008 | Nokia 6300 Cellular Phone
Update problem
Jasim during it's important that it completes the update process or it wont turn on anymore cause the software becomes incomplete and corrupted. Anyways, the solution is to get it reprogrammed. Here in the Philippines we've got technicians charging low prices for getting it reprogrammed. Try looking one from where you're from. It is also possible to contact Nokia and have them reprogram it for you, but that may take some time. Let me know how it goes. :)
Jun 26, 2008 | Nokia N73 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
