Question about Macally Bluewave BlueTooth Wireless Stereo Headset for iPod Wireless Headset
Wireless headphone but no sound
Red and white cable plugs into cable tv and same to plug into wireless sharper image headphones.  Since moving can't get sound!  Had direct tv at the apartment and had it plugged into their direct tv box.  Here at our manufactured home the cable line comes through the wall attaching to the tv. The instructions, however, show to simply plug in the above plugs.  The light on the charging thing is lit but there is no sound coming from the headphones. Can you help us please?  Thanks, Becky
2 Suggested Answers
SOURCE:
  • 10 Answers
SOURCE: blue wave wireless headphone
Please take out the batteries from the dongle and headset for 20 minutes.
Insert a new battery into the dongle, plug into your player and turn it on.
Wait for 2 minutes, insert another new battery into the headset and turn it on.
It will take about 2 minutes to connect each other at first time.
Posted on Jan 03, 2008
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Need instructions for wireless headphones
Plug the red and white cables from the transmitter on the headphone set into the red and white slots for audio out on the TV this will supply the sound to the transmitter which in turn send it to the headphones. The transmitter must also be plugged in to the wall outlet for them to work, and batteries in the headphones must be good.
Nov 24, 2010 | Televison & Video
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
Mar 17, 2010 | Brookstone Surround Sound Earbuds...
Need help with HO 800sentry dynamic wireless headphone?
You need to plug in the RCA plugs (red and white) to your cable receiver box and NOT the TV outlet.
If you have satelite box, it's the same thing. It has two sets of audio-out and one of them goes to your TV and the other set may be free.
If not, goto Radio Shack and get a SPLITTER so you can plug in the headphone set.
However, these headphones... I have one, may not be all that good quality and reliable.
Mar 11, 2009 | Sentry HO900 Headphones
No red plug
Hi and welcome to FixYa,
Initially, the yellow on the TV unit is for video while the white is for mono audio. In cases such as this and the cable to be connected has three, yellow would still go to yellow while the red & white would go together before going into the white by using an adapter as shown below.
If the RCA jacks on the TV says IN, then they will not work as audio source for the wireless headphones. The headphones would need an OUT from the TV. Sorry.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Voyetra Turtle Beach Ear Force X3 Wireless...
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Macally Bluewave BlueTooth Wireless Stereo Headset for iPod Wireless Headset Logo
54 people viewed this question
Top Macally Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Macally Radio Communication Expert? Answer questions, earn points and help others
