Question about Fujitsu MHV2040BH 40 GB SATA Hard Drive
Have Fujitsu MVH 2040 BH hard drive making a steady, low level noise similar to static. Its not that loud but it was not there before. It also occasionally makes a fairly loud single chirp noise that sounds like a bird. The drive is 4 years old. Its in an HP Compaq Presario V3000 laptop. The drive is well maintained with regular defrags. Free space is 55%. Drive is kept clean with regular use of Ccleaner. CHKDSK is also used regulary as well. Average temp of the drive is between 45 to 55 degrees Centigrade. The untilities I have installed to monitor drive health all say the drive is healthy. There are no bad sectors. The computer works fine with no problems. Response to user input is good with snappy speed. Is there anything I can do short of replacing the drive?? I really don't have the cash for a new computer nor even the cash for a new hard drive. Any suggestions to possibly remedy this?? PS; I have all my data backed up via Mozy. Thank You for your assistance!!!
  • Fujitsu Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 10, 2011
Hyundai tucson 07 is making a loud noise. Like something hitting metal. Timing belt/tensioner has been replaced but noise still there. Any hints thankyou.
tappet adjustment, loose exhaust part, loose or worn pulley on the drive belt system, alternator bearings , low engine/gearbox oil level, very hard to pinpoint without being with vehicle but here are a few options to check out , good luck
May 18, 2016 | Hyundai Cars & Trucks
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
My external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Oct 08, 2009 | LaCie Computers & Internet
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
2006 Honda Pilot - Road Noise - not tires.
the tires make steady noise , check the wheel bearing as noises get high and low at the same speed , and i also would check for diff if it's 4wd.
Jul 16, 2009 | 2006 Honda Pilot
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Fujitsu heat pump noise
i would check the blades on the condenser fan motor and make sure they are not hitting anything if they are not, spin the fan see if the fan spin freely, it should, if it doesn't it could be the bearing in the motor are dry and going bad
Jan 22, 2009 | Fujitsu 24C1 Air Conditioner
How do I remove a hard drive from a fujitsu lifebook T 4020 ?
underneath the laptop will be access panels, unscrew them and remove, the hard drive looks similar to this 95631bb.jpg
Nov 24, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Maxtor Hard Drive makes loud noises and my laptop won't read it at all
this is a signal that the read write head of the hard drive is about to stop working finally.
high-level formatting will not resolve this problem,pls prepare to change the hard drive(complete replacement)
Apr 20, 2008 | Computers & Internet
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
See all Fujitsu MHV2040BH 40 GB SATA Hard Drive Questions
Fujitsu MHV2040BH 40 GB SATA Hard Drive Logo
250 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
