My hard drive got bad sectors - Computers & Internet
  • 204 Answers
Hi there!
When you got bad sectors in the hard drive, the data on this sectors may be lost, but the data on the rest of the disk are unaffected and the hard drive is still completely usable.
There is actually no way to repair the bad sectors in the drive. What I can suggest is for you to mark them unusable so that the Operating System will not attempt to store data in that sector.
To do this, just use the scandisk option of your Operating System.
If you have further questions, just reply here.
Thanks!
Posted on Apr 10, 2011
  • 76 Answers
If ur hardrive has bad sectors you mite have to replace it u can usally get a cheap hardrive off of ebay.
Repair bad sector hard
BAD SECTORS
When a hard drive has bad read/write sectors it means the magnetic oxide layer on the disc platters are failing. Before you made an image of the hard drive you should have ran Error Check on the C Drive. This checks and locates the bad sectors and moves the data to an undamaged part of the disc platters and then locks out that bad sector so data cannot be written on the bad sector.
I recommend you do a fresh Windows install on your new hard drive to fix this problem and install the laptop's device drivers plus your programs and data before the hard disk fails completely.
Apr 07, 2013 | Dell Latitude E6500 Laptop
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
I have an 500GB toshiba external hardrive,it still has 50G more space left..however when i tried to open it again..it wont open...it only shows the properties and said that windows cannot correct the bad...
There is no way to fix a bad sector. A bad sector is like a scratch on a cd that can't be fixed. You should run a program like "HD Tune", when you use a program what it does is it will read the disk and when it can't read a certain spot it marks it as a bad sector. After that the hard drive will move the data from the bad sector to a spare area of the hard drive. The spare area will store the data from a bad sector and will be usable like the old one. However if you get too many bad sectors you will run out of spares. When that happens your drive will crash.
You Can Try These Steps: Windows comes with a built-in hard disk utility software that scans your hard disk for errors and attempts to fix them.
  1. On My Computer, select the disk drive that you want to diagnose and repair.
  2. Right click on it and select Properties
  3. Go to Tools tab.
  4. Click on the "Check Now" button under "Error Checking Status".
  5. Depending up on your choice, choose either "Automatically fix file system errors" or "Scan for and Attempt Recovery of Bad Sectors."
  6. Then click on Start.
Jul 10, 2011 | Toshiba 640GB USB 20 Portable External...
This drive is not formateted. bad sectar found
If you go ahead and format the hard drive, fromatting will lock out these bad sectors.
Bad sectors can indicate that the hard drive is wearing out especially if the number of bad sectors increase as you use the hard disk and if this is the case then back up your data regularly so you won't lose your data when this hard drives fail completely. I would consider retiring this hard drive ASAP.
Bad sectors are usually cause by the magnetic oxide layer on the platters wearing out or breaking down.
Nov 28, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
How can i remove bad sectors from my hard disk?????
You can not remove bad sectors from hard drives. Bad sectors are parts of the disk that become unreadable / unwriteable. Hard drives made in recent years simply stop using that part of the drive.
Apr 07, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have bad sectors in my hard disk what should can i do?
There is nothing you can do about bad sectors. The Hard Drive itself, with its associated electronics, automatically maps these bad sectors and doesn't use them any more. So, the answer to your question is "NOTHING". Bad sectors may eventually make your Hard Drive unusable, and if your bad sector count is growing quickly it's time to do a complete backup and replace the drive.
Mar 30, 2010 | Computers & Internet
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
BAD SECTORS
Your hard drive is divided into bits called sectors. When these sectors start to go bad, that means that the computer cannot read or write any data on those sectors. You cannot remove bad sectors and once you start seeing bad sectors it is a sign that your hard drive is about to crash permanently so you need to replace your hard drive and make sure you back up all ofyour important data immediately.
Jul 06, 2008 | Computers & Internet
16 bad sector
Scandisk(or whatever) should mark those sectors as bad, thus preventing them from being used. But no, you cannot erase them, they are physical areas of your disk that cannot properly hold data. Bad sectors are not uncommon, and nothing to be alarmed about, but a loud hard drive is...
Mar 01, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
Hdd bad sectore problim
bad sectors are not fixable as far as hard drives go.
you mmight find software that claims ti fix bad sectors but the claim is false as they only temporarily overwrite the sectors and unmark the bad and remark to good but the problem remains to be the sectors are bad.
The best thing to do is to replace the hard drive with a good used one or a new one.
Sorry but as a technician I know what bad sectors are and what happens when you get them.
Jan 22, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
