Question about Omron Health & Beauty
My Relion Automatic Blood Pressure Monitor doesnt seem to have any inflation power in it, I mean the cuff doesnt grip the arm at all,although you can hear the motor running okay
Max J
  • 22 Answers
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
SOURCE: The Sunbeam blood pressure kit doesn't inflate the cuff.
You have the same problem I do. The hose socket to the machine is broken.
Posted on Sep 06, 2010
guyster7148
  • 192 Answers
SOURCE: my blood pressure cuff wont
Hello there!!! Okie dokie let's dig right in..... The most obvious choice to look at is the line from the cuff to the monitor. Make sure there are no pin holes in it, easy, yet messy way is to lightly dust baby powder on the line then test it, I would do this over the sink, just for spillage. Second, make sure that your batteries are new, the machines are actually VERY good on batteries, but the term LEMON is there for a reason. Then I would check the actual cuff for tears and pin holes, this can also be done with the baby powder, over the sink again, but the nice thing is, the dust will dust right off. If you have a air can for the computer, that works great too. Great help I hope!!! Please remember to vote if I was able to assist you. Take care.... Guy :)
Posted on Sep 15, 2010
  • 4736 Answers
SOURCE: Neither of the cuffs
Robert, I'm not sure that the cuffs would be interchangeable. But, I suspect the problem you're having with the cuff is operator error. Speaking from experience, it's somewhat difficult at best, to apply and arm cuff to yourself. It does take some practice, but if you can get the cuff snugly in place, it should inflate properly. If you want to pursue with interchanging the cuff, contact HoMedics at 800-469-3342, to see if it's possible. Perhaps, you should get a BP Monitor that has a wrist cuff. They're a lot easier to apply and use.
Posted on Apr 01, 2011
What does error 3 on my microlife blood pressure monitor
Repeat measurement keeping arm still. If inflation of the cuff takes too long, the cuff is not correctly seated or the hose connection's not tight. Check connections and repeat
Jan 10, 2015 | Microlife Health & Beauty
An "E" Readin
E is cuff not applied correctly
EE is cuff not inflated properly
E
E
over each other is too much inflation if inflated manually
See page 25 of the manual.
You both need to sit down and read the instruction manual :>)
instruction manual - Omron
https://omronhealthcare.com.au/pdf/SEM-1_Instruction_manual.pdfThe SEM-1 Automatic Blood Pressure Monitor is intended for home use. SAVE THESE ... If the battery fluid should get in your eyes, immediately rinse with plenty of .... These situations could lead to higher blood pressure reading due to strain or the arm cuff ... If an error symbol "E" or "EE" appears, measurement was not.
Nov 06, 2017 | Walgreens Blood Pressure And Pulse Monitor
HD 1000S Blood pressure monitor will not display blood pressure after inflating code ERR 1
tighten the cuff more around the arm or if you have a small arm pull your sleeve down then put cuff on and try it that way see if it helps
Jan 22, 2012 | Health & Beauty
Neither of the cuffs on the Homedics S18729 Ultra-Deluxe Automatic Blood Pressure Monitor work. They do not fit well around my arm and constantly slip while inflating. I don't know if it is a design flaw...
Apr 01, 2011 | Walgreens By Homedics Automatic Blood...
Omron- HEM712C- why does the\r\ncuff opens,when trying to take pressure.
It's likely due to either improperly seating the cuff over your arm, or the cuff being sized to small for the circumference of your arm. First make sure that the cuff is set up properly, the "hook" end of the velcro needs to be facing away from your arm. Once you double the cuff back, make sure that it is not so tight as to be cutting off circulation. If this occurs the force of inflation will cause the velcro to separate. It's also possible that the package included to small of a cuff. If so the manufactor has a largercuff here. http://www.omrononlinestore.com/JHI/guid.569520918/~/productID.4509/US/details.html
Mar 13, 2011 | Omron Healthcare Omron Hem-712c Automatic...
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
Cuff won't inflate
It probably has a leak. Examine the hose and cuff for cracks by flexing it , especially at the fitting where the hose attaches to the monitor. Also check where the hose attaches to the cuff. Try replacing the cuff.
Hope it helps. Please let me know.
Thanks
Apr 22, 2010 | Mabis Automatic Digital Blood Pressure...
Walgreens HD303 Blood Pressure Monitor error 3
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Health & Beauty Logo
151 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
