Question about Nokia E52 Smartphone
I have changed sim cards and Nokia E52 boots in off line mode. No outgoing calls can be made. Nokia Suite says no sim card installed.
  • Thomas Balogh Apr 14, 2011
    I don't see a support solution for Nokia E52.
  • Nokia Master
  • 32,281 Answers
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider. To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use the SIM cardwith a different phone provider, Please click on this link and follow myinstructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB sites - http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ http://www.unlock-free.com http://www.unlock-zone.com/ http://www.unlocking.com/
Posted on Apr 10, 2011
  • Chris Hingee
    Chris Hingee Apr 15, 2011
    Try these other WEB sites, then the security code/restriction code is not available for your cell phone at this stage and hopefully will be available in the near future.http://www.unlocking4u.com/nokia-n73/rs6...http://www.wickedunlock.com/http://www.onlinegsmunlock.com/
Want to reset security access code on my Nokia
To set how your phone uses the access codes and security settings, select Menu >Settings > Security.
The security code helps to protect your phone against unauthorized use. The preset code is 12345. You can change the code, and set the phone to request the code.
The PIN (UPIN) code, supplied with the SIM (USIM) card, helps to protect the card against unauthorized use.
The PIN2 (UPIN2) code, supplied with some SIM (USIM) cards, is required to access certain services.
PUK (UPUK) and PUK2 (UPUK2) codes may be supplied with the SIM (USIM) card. If you enter the PIN code incorrectly three times in succession, you are asked for the PUK code. If the codes are not supplied, contact your service provider.
The barring password is required when using the Call barring service to restrict incoming calls to and outgoing calls from your phone (network service).
To view or change the security module settings, select Menu > Settings >
Security > Security module setting
OR
can look for::
http://www.unlock-free.com/nokia-master/
good luck!
Dec 28, 2013 | Nokia Cell Phones
Phone and sim card pin code for nokia e52-1
phone code may 1111,1234 or 0000 nd for sim card contact company helpline of servive provider
Dec 05, 2013 | Nokia E52 Smartphone
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
My phone e52 sim card regestration failed
This message may be displayed in the following situations:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider. Or alternately, contact your local Nokia Care Point for inspection.
Thanks and have a nice day.
4 Thumb rating motivate us to answer more free questions
Jul 04, 2011 | Nokia E52 Smartphone
Nokia E52 stays in offline mode after swapping sim card
It stays offline if the card is not allowed by your service provider or it is not contacted well.
You can try to clean the metal pins, if it causes a contact problem.
Apr 11, 2011 | Nokia E52 Smartphone
Hi, my one phone is in for repairs. So, I took my SIM card out and put it into my other new phone, a Nokia e52, It's now asking for a PUK no-I can't see a PUK no on the E52'S box. Which Puk no does it...
Hi the PUK code is the security code for the sim card and not any code to do with the phone, all you need to do to get the PUK code is call your service provider.
your service provider wont charge for giving you the code as the code belongs to you, all you need to tell them is your phone number or if you dont know that then the number printed on the sim card, they will then provide you with the 10digit PUK code for free over the phone.
this will then allow you to access the sim card.
The only place you can get the PUK code from is your service provider as their is no where else that keeps these codes, if you still have the card the sim card was attatched to then it will be written on their but if you no longer have this then the only way your going to get the code is by calling your service provider, they wont charge you for this as the code belongs to you,
you do have another option open to you though, if you dont need that sim card then you can go out and get another sim card and when you get given a new sim card you will get given the unique PUK code it will be written on the card the sim card is attatched to.
let me know if you need further assistance ok.
plz rate this solution as i have a whole page of unrated posts, thanks,,,,,
Feb 19, 2011 | Nokia E52 Smartphone
My nokia E5 is in offline mode, how do i switch it to online?
Offline mode is usually caused because the SIM card is not accepted by service provider or SIM card has bad metal contact.
Jan 03, 2011 | Nokia E52 Smartphone
I cannot switch my Nokia E52 back to online
Bad metal contact on SIM card or SIM card is not accepted by service provider.
Nov 25, 2010 | Nokia E52 Smartphone
NOKIA E 52 INSERT SIM PROBLEM help
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
http://www.superunlockcodes.com/nokia-e52/rs12wp9/
Oct 31, 2010 | Nokia E52 Smartphone
Nokia E52 Smartphone Logo
121 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
