My dvd-cd rom isn't working. It is not detected by windows vista. My laptop is HP Pavilion dv2500. When I press the eject button on my dvd-cr rom, it doesn't open either thus it light up. But when I pick the small hole in my dvd-cd rom, it opens and lights up. Then when you return it and eject it again, it is like normal but is still not read by the OS. Need Help Please
  • 91 Answers
There's a big possibility that your DVD drive requires replacement. You can try the resolution below if it didn't work you probably need to replace your DVD drive.
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
Hope this help.
Posted on Apr 10, 2011
HP 9620us no DVD/cd missing?
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct Function key is noted during boot) and make sure BIOS see's the Optical Drive.
Oct 13, 2012 | Computers & Internet
MY CD TRAYS WILL NOT OPEN ON MY HP PAVILIAN A1737C AND THE BUTTONS WILL NOT PUSH IN. PLEASE HELP
Try this:
Start>Computer>Right click on CD ROM drive> eject.
If you do not have a CD ROM drive in Computer (Vista & Windows 7) or (My Computer in XP)
Try This:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
Aug 20, 2012 | HP Pavilion Computers & Internet
Dv9815nr cd rom eject button
Yes there is. Open My computer and right click the CD ROM Drive icon and click Eject. This way you can eject your Optical Drive Tray.
Aug 10, 2012 | HP Pavilion dv9815nr Laptop
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
How to change cd rw in hp pavilion 523n computer
If you can't find the button to eject the CD tray:
Open the Start Menu and go to My Computer (or Computer if you're on Vista or Windows 7). Right-click on your CD drive, and then click on Eject. The tray should eject. When you change the CD and still can't find the button, you should just be able to lightly tap the front of the tray, and it will retract back into your PC.
Jul 06, 2011 | HP Computers & Internet
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
My hp laptops dvd rom is not shown and is not detecting any dvd
Have you used Device Manager and done a search for new hardware? If that has not helped, then you should try to open the laptop to check whether the wires are fully connected, if these are internal.
It is possible that the wires became disconnected, and need to be reconnected to work again.
Try that.
-a.
Apr 18, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Hello
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Andrea
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
After system recovery to factory image everything works like new but..computer doesn't see DVD-RAM i did install driver from HP support site install correctly still doesn't work--device manager shows...
Remove it from device manager by right clicking it and selecting uninstall, reboot and let windows auto detect it again, reload your drivers, visit the manufacturers website for the correct drivers.
Dec 21, 2008 | HP Computers & Internet
CD/DVD ROM disappears
I would think either your IDE cable is faulty or the IDE connector on the motherboard, try swapping cables or use a double IDE cable on IDE 1 connector. You may have a faulty drive ide connection input in which case a new DVD Rom is the answer, only cheap nowadays.
Nov 07, 2006 | Samsung (SC-140B) Internal 40x CD-ROM...
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
