Question about Canon PIXMA iP2000 InkJet Printer
An error occured to my printer says ink absorber almost full. how to solve this?
  • Carol Peake May 04, 2013
    thank you heaps. It is now working .
  • 204 Answers
Hi there!
To resolve this problem, you will need to reset the printer. To do this, follow this simple stes:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope this helps!
Posted on Apr 10, 2011
SOURCE: ink absorber full
I disagree with the advice at printerhelp.me.uk. It is not simple to clean out the ink absorber, but it is certainly possible. First, disassemble the printer, 3fb11e6.jpg then remove and squeeze out the pads of the approx 60 ml (1/4 cup) of condensed ink therein, then rinse them out with water and allow them to dry. Later, reassemble printer and perform a reset as per other articles on this site and others, or use downloadable resetting tool.
As others have pointed out, Canon and other companies are doing a service to us through the error message. If we don't clean the pads, eventually the ink would overflow and leak onto our desks. However, that would probably require 150% of the actual time or ink flow that they have used to activate the alarm.
Posted on Nov 17, 2007
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
please give me resetting soft for canon Pixma iP 3300 printer.
Posted on Oct 06, 2008
SOURCE: waste ink absorber full
my printer is very broken in this so absorber full,it make reset manual,can helm me
Posted on Feb 22, 2009
Joed911
  • 4338 Answers
SOURCE: Ink absorber is full.
Try this:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: canon pixma mp160 ink absorber is full
e75ff09.jpg this the reset wast ink please follow it step by step
Posted on Sep 06, 2009
In printer canon ip 1800 is showing ink absorber is full cant use the printer
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer. Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 31, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is almost full problem is for cannon 1800
Hope you find this information helpful. The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing.Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 23, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
INK ABSORBER FULL Printer model - pixma ip4500 Please solve my problem
This is from the Canon web site.
Before the ink absorber becomes completely full, contact a Canon Service representative. (You will need to replace a particular part of the printer.)
i_important.gif Important
Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced.
There are some links on how to clean it yourself or to bypass the alarms on this site. Just do a search for ink absorber and you should find them. I wouldn't try this unless you are mechanically inclined.
Aug 26, 2010 | Canon Pixma iP4500 InkJet Printer
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP460 Printer - the ink absorber is almost full. What do I do?
Before the waste ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
Feb 20, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
How to solve waster ink absorber full problem in canon ip3300
You need to replace the waste ink absorber and then reset the counter. Generally when these errors occur the waste ink absorber needs replacing, if not your images will start to degrade in quality and you will start to see ink splays / splodges appearing as well as random spots and ink patches. In the mean time press RESUME /CANCEL to continue printing.
Oct 02, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Canon pixma mp160 ink absorber is full
Jul 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP145 Ink Absorber Full Problem.
I got on error message when started to print.
It’s kept happened and message dialog box “The ink absorber is full” occurred.
Mine is Canon MP145.
Can somebody please help me , on how to fix this problem !
tq
Jan 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP2000 InkJet Printer Logo
689 people viewed this question
old marine
old marine
