Crossfire VR2000D Car Audio Amplifier Logo
Posted on Apr 10, 2011
How to run f-cfmodz ver 3.6 - Crossfire VR2000D Car Audio Amplifier
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
957
Points
5
1helpful
What causes obd code u110c
U110C-NO FUEL LEVEL BUS MESSAGE
When Monitored and Set Condition:
When Monitored: Ignition on.
Set Condition: No fuel level BUS messages received by the PCM for 20 seconds.
POSSIBLE CAUSES
DTC RESET
COMMUNICATE WITH BCM
PCI BUS CIRCUIT OPEN FROM PCM TO BCM
BCM
TEST ACTION APPLICABILITY
1 NOTE: If a fuel level circuit or performance DTC is set along with P1681,
diagnose the circuit/performance DTC before continuing.
Turn the ignition on.
With the DRBIIIt, erase DTCs.
Start the engine on and off several times. Leave the engine running for at least 20
second each time.
With the DRBIIIt, read DTCs.
Does the DTC reset?
All
Yes ! Go To 2
No ! Refer to the INTERMITTENT CONDITION symptom in the
Driveability category.
Perform POWERTRAIN VERIFICATION TEST VER - 1 - NGC.
2 Ignition on, engine not running.
With the DRBIIIt, attempt to communicate with the BCM.
Can communication be established with the BCM?
All
Yes ! Go To 3
No ! Refer to the Communication Category and perform the appropriate
symptom related to no communication with BCM.
3 Turn the ignition on.
Using the DRBIIIt, read the Fuel Level parameter in the PCM.
Does the DRBIIIt display a fuel level value?
All
Yes ! Replace and program the Powertrain Control Module in accordance
with the Service Information.
No ! Go To 4
287
DRIVEABILITY - NGC
4 Turn the ignition off.
Disconnect the PCM harness connectors.
Disconnect the BCM harness connector.
CAUTION: DO NOT PROBE THE PCM HARNESS CONNECTORS. PROBING
THE PCM HARNESS CONNECTORS WILL DAMAGE THE PCM TERMINALS
RESULTING IN POOR TERMINAL TO PIN CONNECTION. INSTALL
MILLER SPECIAL TOOL #8815 TO PERFORM DIAGNOSIS.
Measure the resistance of the PCI Bus circuit from the BCM harness connector to the
appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
All
Yes ! Replace BCM in accordance with the Service Information.
No ! Repair the PCI Bus circuit between the PCM and the BCM for an
open.
__________________
3answers
Not playing NTSC DVDs
I can see if there is an unlock code for your device
tip
HOW TO INSTALL FROM SOURCE IN LINUX
HOW TO INSTALL FROM SOURCE IN UBUNTU 9.10
Installing from source in linux is not very easy...... but once you know what to do, then it becomes a very easy task.
STEP 1 Tar.gz and Tar.bz2 Packages
The installation procedure for software that comes in tar.gz and tar.bz2 packages isn't always the same, but usually it's like this:
1.Download the tar.gz or tar.bz2 package
2.Extract the file
3.Open to the terminal
4.Use the cd command to change to the directory where the package is extracted
5.Use the following:
$ ./configure
$ make
$ make install
Without Using The Extraction Method
Run the following:
$ tar xvzf package.tar.gz (or tar xvjf package.tar.bz2)
$ cd package
$ ./configure
$ make
$ make install
!!!!THIS IS AWESOME!!! …... ISN'T IT?
STEP 2 .Deb Packages
Installation of .deb packages are in different forms or methods depending on the users understanding and how the user is flexible with the terminal.
1.Download the package
2.Extract the package
3.Change to the directory containing the package
4.Run the following
sudo dpkg -i package_file.deb
!!!! AND YOU ARE DONE!!!
LINUX X64 AND X86 BINARY INSTALLATION
2.Open to the terminal
3.Use the cd command to change to the directory containing the package
FOR X86 PACKAGES.........
$ chmod +x filename-ver.*-linux-i686.run
$ sudo ./filename-ver.*-linux-i686.runFOR X64 PACKAGES........
$ chmod +x filename-ver.*-linux-x86_64.run
$ sudo ./filename-ver.*-linux-x86_64.run
where ver is the version number (the whole number before the decimal point... eg; the 4 in 4.103)
!!!!THANKS A LOT!!!!
on Jul 21, 2010 • Computers & Internet
How to fix open or shorted relay circuit 3-4 shift solenoid relay condition on 2000 jeep cherokee
Check this TSB...
Set Condition: This code is set if the voltage detected on the 3-4 Shift Solenoid Control
Circuit at the PCM is difference than the expected voltage.
POSSIBLE CAUSES
FUSED B(+) FEED TO TRANS CONTROL RELAY OPEN
TRANS CONTROL RELAY
3-4 SOLENOID CONTROL CIRCUIT OPEN
3-4 SOLENOID WIRING HARNESS INTERMITTENT
SHIFT SOLENOID CONTROL CIRCUIT SHORT TO GROUND
SOLENOID AND HARNESS (SOLENOID CONTROL CKT)
SOLENOID AND HARNESS (SOLENOID PACK CONN)
TRANS RELAY OUTPUT CIRCUIT OPEN
TRANS RELAY OUTPUT CIRCUIT SHORTED TO GROUND
PCM (3-4 SOL CONTROL CKT)
PCM (CODE SET)
POWERTRAIN CONTROL MODULE
1 Key On.
With the DRB, read trouble codes.
Is the Trans 12 volt Supply Relay Control Circuit code set?
All
Yes - Refer to symptom P-1765 TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT in the TRANSMISSION category.
No - Go To 2
2 Key On.
Is the DTC Specific Good Trip displayed and equal to zero?
All
Yes - Go To 3
No - Go To 17
555 TRANSMISSION
3 The code is present at this time.
Key On.
Check and record Freeze Frame data to determine the conditions when the code was set before disconnecting the PCM Connectors.
Note: Freeze Frame data will be erased.
Road test Vehicle. Attain Vehicle speed of at least 50 MPH.
Push OD Switch 4 times such that Vehicle attempts to shift from 3rd to 4th and back.
Did the Vehicle shift between 3rd and 4th?
All
Yes - Go To 17
No - Go To 4
4 Key Off.
Disconnect the Trans Solenoid Pack Connector.
Note: Check connectors - Clean/repair as necessary.
Turn Key On.
With the DRB, actuate Trans Control Relay.
Using a Voltmeter, measure the voltage at the Trans Relay Output Circuit.
Does the voltage fluctuate from 0.0 volt to over 10.0 volts?
All
Yes - Go To 5
No - Go To 13
5 Key Off.
Disconnect the Powertrain Control Module White Connector.
Key On.
Using a voltmeter, measure the voltage at the 3-4 Shift Solenoid Control Circuit.
Is the voltage above 10.0 volts?
All
Yes - Go To 6
No - Go To 7
6 Key Off.
Repair 3-4 Solenoid Control Circuit shorted to voltage.
Reconnect all disconnected Connectors.
Push OD Switch 4 times such that Vehicle attempts to shift from 4th to 3rd and back.
All
Yes - Test Complete.
Perform Powertrain Verification Test VER-5A.
No - Replace the PCM.Perform Powertrain Verification Test VER-5A.
7 Key Off.
Using a Ohmmeter, measure the resistance between the 3-4 Shift Solenoid Control
Circuit at the PCM Connector and Ground (B-).
All
Yes - Go To 8
No - Go To 9
556 TRANSMISSION
8 Key Off.
Using an Ohmmeter, measure the resistance between the 3-4 Shift Solenoid Control
Circuit at the PCM Connector and Ground.
All
Yes - Repair the 3-4 Shift Solenoid Control Circuit shorted to ground.
No - Replace the Solenoid and Harness Assembly.
9 Key Off.
Remove the Trans Control Relay.
Using an Ohmmeter measure between the Trans Control Relay Output Circuit at the
Relay and the 3-4 Solenoid Control Circuit at the PCM Connector.
Is the resistance above 40.0 ohms?
All
Yes - Go To 10
No - Go To 12
10 Key Off.
Using an Ohmmeter, measure the 3-4 Solenoid Control Circuit from the PCM
Connector to the Solenoid Connector.
All
Yes - Go To 11
No - Repair the open 3-4 Solenoid Control Circuit.
11 If there are no potential causes remaining.
View repair options.
All
Repair
12 Key Off.
Using a Ohmmeter measure between the Trans Control Relay Output Circuit at the
Is the resistance between 26.0 and 40.0 ohms?
All
Yes - Replace the PCM.
557 TRANSMISSION
13 Key Off.
Key On.
Using a Voltmeter, measure the Fused B(+) Circuit in the Relay Connector.
Is voltage above 10.0 volts?
All
Yes - Go To 14
No - Repair the open Fused B(+) Feed to the Trans Control Relay.
14 Key Off.
Using a Ohmmeter, measure the Trans Control Relay Output Circuit from the Relay
Is the resistance above 5.0 ohms?
All
Yes - Repair the open Trans Relay Output Circuit.
No - Go To 15
15 Key Off.
Using a Ohmmeter, measure between the Trans Control Relay Output Circuit and Ground.
All
Yes - Repair the Trans Relay Output Circuit shorted to ground.
No - Go To 16
16 If there are no potential causes remaining.
All
Repair
Replace the Trans Control Relay.
17 Key On.
Check and record freeze frame data to determine the conditions when the code was set.
Erase the DTC.
Warning: This will erase the Freeze Frame data.
Attempt duplication of Freeze Frame Data to help reset the code.
Key Off.
Using the Schematic as a guide, inspect the Wiring and Connectors.
Were any problems found?
All
Yes Repair as necessary.
No Go To 18
558 TRANSMISSION
18 Key On.
Note: Actuate the 3-4 Solenoid or the test can be done with the Engine running.
Wiggle the Wiring Harness from the Solenoid to the PCM.
Note: You are attempting to set the code.
With the DRB, read DTC's.
Does the 3-4 Solenoid Control Circuit Trouble Code appear?
All
Yes - Repair as necessary.
No - Test Complete.
559
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
1helpful
Failing to initialise d3d when trying to play tekken 3 game
if problem with d3d
then you need install a other version of windows
because your game need newer version of d3d
i think you are using windows xp which have a direct x ver. 9
so you need directx ver. 10 or 11
you have two chices
you may go for windows vista which have directx ver. 10
or for windows 7 which has directx ver. 11
i thinck you understant
2helpful
Need to download ageia physx driver ver 2,8.1 to run game everytime i try to launch the game it says install latest ageia physx drivers ver.2.8.1
if you are trying to run empire earth 3... just uninstall it... even with the driver... it is downright awful... with choppy video and action... very bad... but if you really need it go get the driver go here...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
194helpful
7answers
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Sony driver update
You can down load the driver for vista of sony DCR- DVD 100E/DVD 200E from the following links
This chart provides compatibility information for software that ships with Sony digital cameras and camcorders.
Note: Not all software applies to all models. If uncertain, please refer to your product manual to determine which software came with your model.
Software Compatible Additional Comments Movie Shaker™ software Ver 3.1 for MICROMV camcorders No N/A Nero® Express 6 No N/A Pixela ImageMixer™ for HDD Camcorder No Please update to Picture Motion Browser Ver. 2.0.11
Note: This software is not applicable to all models. Pixela ImageMixer Ver 1.0 No N/A Pixela ImageMixer Ver 1.5 No N/A Picture Motion Browser Ver 1.1 Yes Some behavior may be different from that of the previous Windows XP operating system environment. *3
Please install the update program for Windows Vista. Picture Motion Browser Ver 2.0.01 – 2.0.06 Yes Some behavior may be different from that of the previous Windows XP operating system environment. *3
Please install the update program for Windows Vista. Picture Motion Browser Ver 2.1.00 – 2.1.01 Yes N/A Pixela Picture Package™ software Ver. 1.0 – 1.7 No Please update to Picture Motion Browser Ver. 2.0.13
Note: This software is not applicable to all models. *2 Pixela Picture Package™ software Ver. 1.8 No Please update to Picture Motion Browser Ver. 2.0.12
    *1 It is not possible to save RAW files in the SRF format with the Image Data Converter SR software.
    *2 It is not possible to create a Video CD using Picture Motion Browser.
    *3 Examples of behavior variances:
    Display -
    • The Picture Motion Browser short-cut icon may become a Windows-standard icon.
    • The tooltip information window may not be transparent.
    • images may not be displayed properly in the browser window while playing back movies.
    • Some images, character, and icons may not be displayed properly.
    Sound -
    • The volume control bar in the browser may not be operational when playing back movies.
    • While playing back movies the sound may not be output.
    Other -
    • Some folders, such as public folders, cannot be registered as Viewed folders.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
Top Crossfire Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
