Question about Heavy Machinery
Looking for blade assembly for a Steinmax Trojan 1100 chipper
I over tightened the blade on my mower so the pull cord is too tight how do i loosen it
If you used the pull cord to hold the shaft while you tightened the blade, you damaged something in the pull cord assembly.
Sep 05, 2014 | Troy-Bilt Troy Bilt Genuine Troybilt Mower...
I obtained a used Steinmax 1800 chipper shredder. I was told it worked, but when we plugged it in, it only gave a hum. My husband (NOT even remotely a fix-it type guy), took some of it apart, loosened a...
I have one of these and LOVE it. Usually what you describe is caused by debris keeping the rotor from turning. Check it again (take off the top part) and be sure the thing spins freely. They're very reliable, in my experience, but you can't let the blade get jammed.
May 09, 2011 | Heavy Machinery
I'm looking for an owners manual for a Gardenway Chipper Vac model 47031
I have a owners manual for a Garden Way Chipper/ac Model 47031. Contact me and we'll figure out a way to get it to you. banderson@ptd.net I'm looking for someplaxce to buy the Fan & Chipper Disk Assembly, P/N 1763255. Anyone ave a source?
Oct 11, 2009 | Troy-Bilt Heavy Machinery
I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Oct 08, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
How to remove impeller assembly from chipper
You can download a PDF2.gif manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795890 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer2.gif where you can either save it or print it out or both
Aug 16, 2009 | Heavy Machinery
Broken Bosch AXT 2000 HP Shredder
Chances are there is a branch wedged in the blade assembly. Are you able to pull the starter cord? if not, you'll have to remove the housing that covers the blades and remove the blockage.
When you expose the blade use a bar to reverse the blade and release the tension, If it was blocked it should start up right away.
May 04, 2009 | Heavy Machinery
New dado set understand the shimms and chipper work
The shims are placed between the blades and chippers in a stack. they are used to make very small adjustments to the final dado width... So usually you set up your dado set for a specific width of cut according to your blade chart, then make a test cut... If you need to widen the cut very slightly, add some shims in between the blades as required to get a good fit on whatever material you are joining or putting into the dado etc.
Hope that makes sense!
Please rate this solution on FixYa!
Apr 12, 2009 | Delta 35 7670 8" Stacked Dado Set
My chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Mar 31, 2009 | Heavy Machinery
Heavy Machinery Logo
75 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
