Question about Samsung Televison & Video
My 42 q96 plasma strarted to lose it's picture after a while. I checked all boards for dry joints. Found I believe the startof caps bulging on power supply. Now I get what I can best describe as I have a picture but imagine in large patches colours diminished as if no power to cells it's dark in patches of the screen but the main thing it's in patches not consistent throughout the whole screen.
  • 20 Answers
SOURCE: 42 LG Plasma picture distorted and flickering
replace the control module.
Posted on Mar 11, 2009
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
maatmartin7
  • 1213 Answers
SOURCE: I have a 42 LG Plasma TV with a broken screen
NO....You must pay attention to all numbers on the back of the TV. Verify these with your tech or contact your LG customer support for the correct board numbers. If the screen was broken I doubt if you can repair this for less than it cost to replace. The screen for this one runs at about $650.00. Good Luck and good advice!
Posted on Oct 01, 2009
futurework
  • 70 Answers
SOURCE: insignia ns-pdp50 plasma. pop of death, audio but no video
I suspect that your supply has gone bad. You will need to find the service manual for voltage measurements. If you want to get replacement boards many can be found on ebay or you can check www.shopjimmy.com they stock boards for many units and I have had no problems.
Posted on May 04, 2010
itvrepair
  • 28 Answers
SOURCE: 42PC3D 42 in. Plasma Television: SCREEN ON 42 IN. PLASMA LG PICTURE LOOK DARK YOU C...
how dar is the picture ?
i can help you if you have more details
Posted on May 19, 2010
Tv powers on lights come on but never picture or sound? Dell 42in plasma?
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I
Dec 20, 2010 | Dell W4201C 42 in. Plasma HDTV
My Samsung plasma 42 "
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Dec 19, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
My 42 inch vizio plasma tv plays sound but no picture
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Dec 16, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
42" Fujitsu plasma. Picture went out and the power
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
Dec 14, 2010 | Fujitsu Plasmavision P42HHA10 42 in....
My 42" plasma hitachi will quit working for a bit
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Kaufman605
Dec 13, 2010 | Hitachi 42HDT79 42 in. Plasma Television
My 42" Vizio Plasma TV will not power up with
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
My hp 42" PL4260N has sound but no picture. I
Kaufman605
Dec 11, 2010 | HP PL4260N 42 in. Plasma HDTV
5 blinking red lights when turned on
When you remove the bad check for bulged electrolytic caps, that need change, or change out the power supply.
Oct 18, 2010 | Samsung SPN4235 42 in. Plasma HDTV
The picture goes out after about 10m min in use stays off ffor about 5 seconds then comes back on, it does this several times while watching a program
This fault suggests that you have a bad joint somewhere on the tv. If you feel competent to do so,remove the back and check all lead connections.If secured ok put power on and wait for fault to occur and when it does, listen for any arcing or strange buzzing noises coming from the power supply. If so, there may be a dry solder joint on the power supply. Also check for bulging capacitor tops with possible brown fluid discharge on the central power supply board..If this is present, replace the capacitors..Samsung plasma tvs are prone for this, and if ignored, eventually the tv will not come on at all and keep tripping on and off.
Oct 17, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Dead set, Akai 42" Plasma PDP4294, no power
Porblem solved,
It's a wonderful day.... Ahhhh, it is now FIXED and working great. I found cracked solder joints on a few of the switching power transistors and some of the big diodes and other heat producing parts. Also notice that the infamous Red caps C524 and C523 were discolored but they checked OK on my cap meter and also my ohm meter, however while I was inside the set after removing 1 million scews I decided to replace them anyway.
I hope that my repair success helps someone.
electricitym
May 07, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Henry  Thomas
Henry Thomas
