Question about Sony HDR-XR100 AVC Camcorder
Sony HDR XR-100 error code E:61:10. Have tried reset button and removed battery and restarted but didn't help. Any way I can still try before sending it to service?
SOURCE: HDR-HC1 power keeps cycling
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
Posted on Dec 29, 2007
DocG4
  • 3 Answers
SOURCE: Tape is stuck in my Sony handycam DCR-PC101
I have managed to eject my tape by powering 4.5 V the little motor which drives the eject mechanism.
Problem is that you have to dismantle half the camera to do this (be very careful with the flexy wires they are fragile) and I wouldnt' do it without the service manual.
Posted on Dec 24, 2008
SOURCE: Video camera displaying Error code C:31:23
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
Posted on Aug 03, 2008
  • 5 Answers
SOURCE: Sony TRV460 error code C31:22
try slapping it at the side of the tape and than maybe push the reset button, it must solve your problem, its probably the little lever inside that tells the camera that there is a tape inside
Posted on Dec 04, 2008
SOURCE: HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Posted on Mar 30, 2009
Hdd format error. not record image & video
hi,
try to reboot your cam...
if it doesn't work, the drive may be dead or just disconnected by a small chock,...
what ever you will have to open it to change the drive !
cheers
mich
Dec 19, 2013 | Sony Handycam Hdr - Xr 100 80gb Hdd High...
Camcorder sony hdr-ax2000e turns itself off
hello, does it show any error code before is shuting down?
May 28, 2013 | Sony HDR Video Cameras
Have E:61:10 flashing up on screen. cannot find it in manual. can you help. Sony hdr-cx520ve
error code alerts user for malfunctions detected by the camera. the error E:61:10 would pertain to the zoom mechanism malfunction. issue may be with with lens block zoom MR sensor or zoom motor drive circuit. 1st step troubleshooting steps would be to reset camcorder (check manual for reset button location) and power reset (remove battery and leave camcorder w/o any power source for a minute). if still the same then service would be required. hope this info helps. thanks.
Jun 02, 2010 | Sony Video Cameras
E91 Error
Manual says needs repair. Cannot find a reset button on mine. a Sony guy said to remove battery,disconnect power.....turn button to on , leave for 5 minutes....turn back to off....reinsert battery and power
May 20, 2010 | Sony Handycam HDR-HC3 HD Camcorder
Sony model hdr-hc1 moisture error code c:21:00
Had same issue, tore hair out for days. Fixed by cleaning little sensor at the back on the left (towards lens) inside. Its about 5 mm by 4 mm copper with black centre. Cleaned with alcohol cotton tip. Left for a day. This still didn't fix it. In the end i reset it and swapped batteries. Presto! Working again, happy Camper. I still believe the sensor needed cleaning (as did have gunk on it) and that's what triggered the issue in the first place, then swapping the battery and also hitting the 'reset button did the refresh the system needed to release it was clean. Done. Hope that helps! Who would have thought to swap the battery ? But that got it in the end. Good Luck
May 10, 2010 | Sony HDR-SR10E HDD Camcorder
I get a error code 30:23 on my HDR HC3 and it won't play or
Sony is pretty secretive about the :23 code. It can't be found anywhere. Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 120 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Nov 12, 2009 | Sony Handycam HDR-HC3 HDV Digital...
Bill,
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Unable to text from my Sony Ericsson k850i
try reset all settings,go to settings and master reset,heres the codes,0000...gudlock
Feb 17, 2009 | Sony Ericsson K850i Mobile Phone
Sony XR-C2600 car stereo stuck in demo mode
Sony XR C2600
  • Press release button on faceplate.
  • Remove the faceplate.
  • Clean the contacts in system and faceplate with alcohol.
  • Voila, all button works now
Bullet Sankar India
Feb 05, 2009 | Car Audio & Video
Sony HDR-XR100 AVC Camcorder Logo
256 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
