Question about Daewoo Washing Machines
It wont drain on spin cycle what can i do? model is DEF-6094R 6Kg
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 11, 2011
My 6kg tempo top loader washing machine won't drain or spin . Would you know what may be stopping it from doing that ?
Could be lid switch thinks lid is up. Or timer contacts defective for drain and spin functions. Or bad pump, or bad solenoid for drain function.
May 20, 2014 | Washing Machines
Simpson encore 605
Sounds like a motor transmission problem.190.00 parts and labor is not a bad price.
Check if there is a warranty with the new parts the service person is installing.
Oct 27, 2011 | Washing Machines
I have a whirlpool a+a 6kg aw o/d 4606 type d 400 which is telling me to clean pump . my question is where is the pump ?
Hi mooneyorla,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
I have a hotpoint aquarius 6kg washing machine, i need to cancel a progeamme and drain the washing machine as their is a sleeve caught in the door and water is coming out but don't know how to please...
hiya
if the model starts with wm then you should set the timer knob just before a spin setting and it will empty out.
if the model starts with wma,few or wf then you will have to hold in the start button as this will cancel the current cycle and should start to drain.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 05, 2008 | Hotpoint Washing Machines
Having issues with my washer Model # LSR7010PQ0. Will not perform final spin cycle. All the water is draining.. basket just wont spin. Tried the spin cycle on one of the other settings and that worked. ...
As the machine goes through the cycle, it should do what is called a neautral drain (drains water without the tub spinning) then a momentary power intreupt allows the gear to slip down and the spin begins. If this is not occouring on one cycle, it is usually a bad timer.
Jun 13, 2008 | Whirlpool Washing Machines
Daewoo dwf-6094r wont spin on spin cycle
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And rate me pl, if the solution has worked......
Dec 02, 2007 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
