How do we ensure that we always get a cold wash cycle ie prevent machine heating water? Obviously we don't have a User Manual! Thanks for any help. Martin T
    Brigadier General:
  • 6,277 Answers
2 problems, first you do not say the make and model (!) and second->
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
John C.
Posted on Apr 11, 2011
Please tell me if an NA VR5500L Panasonic washing machine has a water heater? If it does, how does it work? the drain coming out is cold. THANKS A LOT
The only appliance that heats water internally for cleaning is a dishwasher. Washing machines don;t heat water. It's not efficient. Various industries have work their hardest to keep you from using hot water or the chemicals(phosphates) that help you clean better without it. Dishwashers warm 3 gallons no more than 20 degrees during a 30 minute cycle. Some washing machines are designed to avoid hot water completely and call themselves energy effient to get people to buy them. My wife would cut my heart out if I brought one home.
Aug 24, 2015 | Washing Machines
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
Whirlpool duet washing machine Hot and cold water are inverted when filling up the machine's bassin: I choose cold water and it fills up with hot water. The rinse cycle is fine though.What could be the...
The Cold inlet for this machine is on the right side.. with a blue indicator ring on it. When I say Right this is looking at the machine from the back.. Left if looking at the machine from the front. in other words the inlet closest to the edge of the machine.
If you are able to pull the machine out from the wall a little.. Start the fill cycle with cold water reach behind the machine and feel the supply hoses. If the hose closest to the edge of the machine is warm.. you simply have the hoses hooked up wrong.
Turn off the water.. swap hoses.. and all should be well..
I doubt the blue colour ring was put on the wrong inlet.. but.. stranger things have happened.
The Hot inlet should be indicated with a red colour ring..
In most installs the hoses will cross over each other.. not unusal at all. Always use new hoses when installing a washer.
Good luck
Feb 27, 2011 | Washing Machines
When I do not use my Indeset W90 for a week or more, there is a lot of water in the drum. Do you know what causes this and how I can solve the problem? I have been told by a friend that the filter may need...
U have a valve problem (Hot and Cold value in this machine.) Read handbook. Perhaps it is plumbed incorrectly and, or, is a "Cold Wash Machine, Please Check your manual. Also faulty plumbing as water gathering. when unussed as "leak" . First empty water by rinse cycle to see if this empties water completely. Filters need claeaning on a regular basis. May be at back bottom of drum , again check manual. If no manual go to high street outlet and look at same type of machine and quickly study the manual supplied for that make of washing machine. Recheck plumbing and the valves. Is worth calling a trained plumber for this machine
Jan 12, 2011 | Indesit Washing Machines
Why does it take over 2 hours to wash a normal load, is there a manual for this machine
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I don’t know what machine you have but the newer energy efficient machines do take far longer to complete a wash because they are basically cold fill. Part of the wash cycle is incorporated in the heating stage. Companies are all striving for the prestigious ‘A’ rating on Energy, Wash and spin, but in doing so have to increase the wash time. Sounds wrong it’s how it works! If you need a free user hand book then click on user manual and select your manufacturer.
Mar 06, 2010 | Washing Machines
I recently purchased an LG WM2301HW washing machine. I was wondering if this particular unit automatically controls the temperature of the water on a particular cycle or if the warm water needs to be...
page 22 of the user manual states that warm rinses are regulated at 86F (30C) it states that there is a heating element as well to boost the temp to normal hot water temperatures (90-100 C)
Apr 11, 2017 | LG WM2301HW Front Load Washer
Forgot how to use
Doing a Load of Wash for Portable/ Kitchen Faucet
1) Make sure machine is set to Cold/Cold and never use Hot/Cold button (Hot/Cold is only for permanent hook-ups). Connect water hose to kitchen faucet. Turn on water to temperature of choice.
2) Load machine half to three-fourths full of clothes. (only half full is recommended if you intend to use the dry cycle right after the wash cycle. For half loads, push in the half-load button. )
3) Add detergent and fabric softener:
a. Liquid detergent into 2nd slot: only 1 tablespoon, 2 tablespoons maximum
b. Fabric softener into 3rd slot. this really helps in preventing wrinkles
(****NOTE: THE MOST COMMON AND MOST DAMAGING ERROR IN THE USE OF FRONT-LOADING MACHINES IS OVERSOAPING. oversoaping causes - pump failure, drain failure, etc. - none of
which are covered by the warranty. The only reason top
loaders use so much soap is because they use so much water and this dilutes the soap. Also, always use detergents that have an HE -- High Efficiency -- rating.)
4) Select Wash Cycle
Permanent Press is likely to be fine (32 minutes) as the USA has softer water than in Europe for which machine was originally designed. Hard water, as in Europe, means it requires more detergent and more washing motion than in the USA. Prewash and/or Superwash (53 minutes) might be preferred for dirtier clothes.
5) Select Spin Cycle
600 should be fine. A higher cycle means dryer clothes, perhaps more wrinkles, and certainly more noise. (Malber USA suggests 800-900 as the norm).
6) Make sure Spin cycle has cold water.
Faucet should be changed to cold water AFTER the initial fill even if you are not drying - all rinses should be in cold water for more complete removal of soap residue
If you use Dry Cycle
7) Select time for desired dry cycle. Make sure to change the faucet to cold water. If you do not want to use Dry cycle, select 0 minutes. Otherwise, use 120 minutes the first time until you can gauge what types of loads require how much drying time. Here's how the Dryer works: A heating element inside the washer heats up the load. During the dry cycle, as the cold water from the faucet circulates into the machine (in tubes, not mixed in with the load), it cools the steam and condenses it into liquid water which is pumped out.
After Wash & Dry
8) It takes approximately 90 seconds after the cycles are completely done before it allows you to open the door. Malber USA says it is due to safety requirement of UL. Who knows what UL security feature is for. Perhaps extra time to finish draining.
9) door slightly ajar to let the machine dry out. I have read postings that say the machine becomes smelly with mildew if you do not. Malber USA says this is true for all horizontal axis (front-loading) washers.
Most common complaints
1) Using too much detergent.
Front loader machines do not need so much water, and thus not so much detergent. Also USA water is softer than European water, for which the machine was originally designed, and that may explain why the detergent compartment is so big to hold more detergent. Soft water is easier to get suds. Damage is caused by suds. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element.
2) Dryer does not work, for several main reasons:
(thanks to Malber USA for points a and b)
a) the system may have overheated, tripping the safety thermal switch. This switch is located under the top of the machine and can be easily fixed by the consumer.
b) broken working thermostat. It is a relatively inexpensive repair to remove and replace this part and takes only about 10 minutes. It can be done by the consumer but it
is recommended that a qualified tech do the job.
c) Machine is too full and/or fabrics are too heavy.
Even though you can wash a maximum load of 11 lbs. of clothes, the manual suggests to dry no more than 7 lbs. of cotton clothes and 5 lbs. of heavy or extra large fabrics. Thats because the dryer works by heating up the clothes and then condensing the steam from the circulating air into liquid water which is pumped out. If the machine is filled too much or if the fabrics are too dense (e.g., jeans), the system cannot condense enough water and the clothes remain humid. Perhaps a second 2 hour dry cycle could work, but who wants to dry clothes for 4 hours.
d) Broken heating element
Seems that the heating element breaks after 2-3 years and needs to be replaced. And why is that? Most common reason for heating element failure is oversoaping. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element. But many people simply choose to not use the dryer rather than have it fixed.
Hope this works. Please be sure to rate me. thanks
Apr 17, 2008 | Malber WD1000 Front Load Washer/Dryer
LG WFT1391TP Top Load Washer - Black Clay Pieces in Drum
Lint build up. good hot water wash with bleach should do the trick
Nov 18, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
