Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I have a 4gb cruzer that's password protected by U3. Apparently I don't know my password (I know I'm inputing the correct one) and I have one chance left before it says I will be locked out permanently and it will have to be formatted to be used again which would, of course, lose all my data. Is there a way to find out my password or recover the data if I have to let it format? Thanks in advance
  • SanDisk Master
  • 27,725 Answers
Im not sure about passwords on usb drives but
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on Apr 10, 2011
Sandisk U3 Cruzer Micro 4Gb Cant Format
With your computer on and the SD Flashdrive fitted correct side UP in the USB port, go to 'My Computer' on the desktop and select the flash drive. The computer will ask you what function you want to perform on the drive and you must select 'format.' You did not say what kind of operating system you are using or I could give you more information. Let me know what happens,
Sciencewoman
Apr 01, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My password protected scandisc cruzer usb stick is refusing to accept the correct password-any solution
Unfortunately, you can NOT access your user data and applications on the device without a password.
If you think you are entering the correct password, ensure that CAPS lock or NUM lock is not turned on. You should try to type your password in another application (like word or email) to ensure that it is being entered correctly. This can help you see if CAPS lock, NUM lock, or a sticky key is causing the password to actually be entered incorrectly.
Password attempts
There's a set number of attempts before U3 locks your device and you have to reformat it.
Reformatting will delete all files and applications on the flash drive.
Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password you will have to reformat the drive.
It is recommended to keep a backup of all the data on your U3 device on your PC for safe keeping.
Jan 16, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Dear Team Today when i try to use my CRUZER U3 (8GB) I GET MESSAGE "you have reached the maximum number of failed password...
Each U3 smart drive comes with a pre-defined number of login attempts. When you have only 3 attempts remaining, you will receive a warning message to prevent losing your data unnecessarily.
SanDisk does not have any method to bypass the password security feature on Cruzer U3 flash drives. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you exceed the number of incorrect password attempts, the drive will lock. Once the drive is locked there is no way to unlock the drive or gain access to the data stored on the device. You can only select the format feature, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. U3 Cruzer flash drives which are password protected use 128bit AES encryption for data security
http://kb.sandisk.com/app/answers/detail/a_id/191
Sep 23, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Cruzer micro 4gb does not start on windows xp
If you are using Windows.
Open the Windows explorer.
Plug the device in a USB port and wait for the computer to recognize it. After it is recognized the Windows Explorer will show two additional icons, one of them a CD-ROM.
Click the icon with the CD-ROM, and it will execute the U3 operating system. A small yellow icon with a U3 label will appear on the task bar. Right-click the icon on task bar and select the "Open U3 Launchpad". Point to the Settings button on the right side.
Right click that button and select the U3 LaunchPad settings
In the window that pop up point to "Autorun" button and click it.
Click the button that will say Enable.
After that it will launch automatically whenever the device is recognized by a computer.
If the U3 launchPad is missing from the device you can download it from the SanDisk site. Here is the link. Download it and install it on your computer. Note:It does not launch on MacProducts or Linux.
Jun 28, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Can I password protect my Cruzer USB 2.0 Flash Drive, 4 GB for in the case I loose it?
The Cuzer has its own encryption software. Plug the Cruzer in a USB 2.0 prt on the computer. If the Cruzer LaunchPad does not execute by default, use the Windows explorer to explore My computer. You will see two icons related to your cruzer, one of them is a CD_ROM. In fact it is the LaunchPad of the U3Smart OS that come swith the Cruzer.
Click on the CD-ROM icon and an a yellow icon (U3) installs on the system tray. Click on it. A pop-up window deploys. Click the Settings button on the right side (2nd menu on the right, under explore drive). You will have to configure U3 LaunchPad Settings. Select Security and enable security.
You will be prompted for a password.
Warning: If you use the Cruzer on Macs or Linux, you will not be able to open it on these OS's if security is enabled. You will be able to open it on Windows only.
Hope it helps.
Thank you for using FixYa.
Nov 18, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
U3 system doesn't run
Sandisk offers a program that completely wipes the Cruzer (including the partitioning), turning the drive into a pure unit. This is a permanent solution, and one cannot restore U3 functionality once this has been done. I hate the U3 stuff, so this is something I do with every Cruzer right out of the box.
Doing a search on Google for 'u3 removal' yields a few links, but at this moment, I'm running into a lot of broken links, and the original page on Sandisk's site (where I got the utiliy in the first place) is broken. I use the utility far too much to not be sure of having access to it, so I made sure to have it in my numerous 'essentials collection' CDs at home and work, as well as on my personal page in case I ever was somewhere without the CD.
One note about the version I have.... it is the Windows program, so if you have a Mac, you'll have to go to Sandisk and get the Mac version. I have no idea whether there is an option in Linux, but I'd be surprised if someone hasn't done it. Again, the Google results I got seem to have a lot of potential
Another thing, I have used this program flawlessly on a pile of 1GB and 2GB Cruzers. As far as I know, it will work on other sizes, but just so you're aware, I can't be 100% sure of that.
If you want to grab the Windows executable from my collection, go here: http://www.rawbw.com/~zio/misc/u3/U3Uninstall.zip
Hope this helps!
Feb 22, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
108 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
