Question about Toys
FORKLIFT CAT DP30N SER#T14E-32705. INDICATES A CODE P-22 AND DOES NOT MOVE. AFTER SWITCHINH OFF AND THEN ON, SOMETIMES IT MOVES THEN STOPS
pineworks
  • 4041 Answers
SOURCE: Error code 6A00 print head not moving. Sometimes
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Posted on Jan 25, 2010
SOURCE: no brake pressure Cat t50d forklift.
thottle linkage on t50d catipiller forklift anyone know how it goes on
Posted on Mar 09, 2010
rabbitbrains
  • 575 Answers
SOURCE: L.P. powered forklift will not move in reverse.
Check for blown fuses and check the reverse solenoid. You can swap the forward solenoid with the reverse one. If it works, then replace the solenoid.
Posted on Apr 30, 2011
Hobbit_who
  • 2044 Answers
SOURCE: While driving, The speedometer needle sometimes doesn't move from zero.
IS this a Chevrolet? What year?
There is a known problem with the Instrument Clusters and you have to replace the Stepper Motors to get it to work correctly..
This is true for most Makes and Models but Especially in GM Products I will only rebuild a Cluster with a X27.168 Stepper Motor
Posted on Apr 15, 2013
skychief2001
  • 21873 Answers
SOURCE: My vehicle was moving then later indicate neutral and stop I try to engage the gear but the vehicle won't move why
If the gear indicator changed to neutral without you doing anything, I would say the transmission selector switch has failed. The switch tells the computer what position the shifter is in.
Posted on Jul 04, 2013
I have a TCM fg20 forklift that here lately seems like you have to give it more gas to move . It's propane powered. Any idea what to check ? Scott
all forklifts have an isolator valve in the drive system that stops the vehicle movement if the foot is on the brake
that area of control is where I would be looking at because if the valve is not allowed to neutralize properly then it stops movement or only allows partial movement
Dec 04, 2016 | Cars & Trucks
What is error code F-85
There isn't one listed.
71 Timer stop idling
75 Oil temperature sensor circuit hydraulic steering system
The pressure sensor 81 at the inlet trap foreign particles
82 Pressure Sensor
84 speed sensor
91 Accelerator pedal position sensor
94 Pressure Sensor fuel pumping
95 The differential pressure sensor on the fuel filter
Jun 19, 2014 | Caterpillar Cat Forklift Ignition Switch...
I need help on a problem i posted yesterday about a Crown model 35SCTT electric forklift that will not move forwards or backwards. It will however raise, lower, and tilt the forks. The forklift is just...
Buy a new gas or diesel forklift. Saves lots and lots and lots of down time and aggravation!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you need to buy, rent or need services on gas or diesel forklifts and you are in South Africa you are welcome to email me at yvonne.finch@gmail.com
Aug 01, 2013 | Crown Forklift Spray Paint Can Beige Part...
L.P. powered forklift will not move in reverse. Forklift will lift, shift, and move forward, but will not move in reverse. While in reverse the engine will rev up, but there is no reverse movement...this...
Jan 29, 2011 | Toyota Bp- Toyota Forklift
Tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
Jun 21, 2010 | Clark Forklift Horn Button Switch , Cat...
No brake pressure Cat t50d forklift.
Mar 25, 2009 | Caterpillar American Construction...
When steering forklift 5FBE18 want move
you have a welded directional contact . You need to change all directional contact tips.
Mar 18, 2009 | Home Fencing
Toys Logo
302 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
